So much Work.. My Super Stock Induction
I'm Old School to the bone. I have a program for these but I choose to spend 75 hours doing them by hand! It's a weird pride thing... I have things I'm going to try since they are mine...
You know I love burr and wings...
Heads are the 90947 angle plug Edelbrock. Manifold is Victor E. Combo is the '70 LT1 350.
Re: So much Work.. My Super Stock Induction
Besides endless grinding and filling, it's endless CCing!!!
Lots of work for sure there. Curious about the epoxy in the first pic. Will they all be filled in or?????
Nothing has ever been discovered or learned without stepping out and giving it an attempt. I like your thinking Chad, hope you are pleasantly surprised with the outcome. Mark H.
Are these the heads you showed in your YouTube video?
Any idea how these “substituted” castings compare to legal factory castings?
I love to follow along when very knowledgeable and talented people get to try things on their personal stuff. Thanks for sharing.
Man talk about works of art, nice work there Chad, you always give me new ideas to try.
That is quite a reduction in port volume with the epoxy!
Yes all he ports will have epoxy. They come 185cc and rule is 172cc so they have to be shrunk.
Yes same head design but different heads.rustbucket79 wrote: ↑Thu Jan 20, 2022 8:31 pm Are these the heads you showed in your YouTube video?
The OEM isn't a fair fight anymore. These have 15-20 cfm on them.
NHRA makes you add 5lbs per to run them.
So 350/360hp is rated at 325 OEM and 330 aftermarket
Say you want to run a 10lb class. OEM = 3250 and AM = 3300lbs
Will the seat inserts on the Edelbrock heads take 1.94 /1.50 valves for engines needing that size valve as per NHRA .
glad to see you were able to find a Victor E manifold .Manifold is Victor E
do you have anymore to sell ??
These tools put a 2.200 intake seat ring in a head that can only have a 1.94 or 2.02. It's a MAJOR pain in the ass, and just stupid. The registers need welded. That big seat ring suck for a proper valve job.6.50camaro wrote: ↑Fri Jan 21, 2022 1:16 pm Will the seat inserts on the Edelbrock heads take 1.94 /1.50 valves for engines needing that size valve as per NHRA .
About the best you can do, this top cut is .120 wide and still leaves a step.
