Thicker Rod Bearing ( non-typical ) application .
swampbuggy
Post by swampbuggy »
Have any of the insert bearing manufactures produced a Bearing to use in a Big End Bore Size of 2.0152" and work with a 1.850" journal. The bearing shell would need to be right at .0825" thick . Thanks for any replies, Mark H.
modok
Re: Thicker Rod Bearing ( non-typical ) application .
Post by modok »
Probably no.
It is better to make the rod the right size.
for low performance applications you can use shim stock.
ProPower engines
Post by ProPower engines »
swampbuggy wrote: Wed Jan 26, 2022 10:18 pm Have any of the insert bearing manufactures produced a Bearing to use in a Big End Bore Size of 2.0152" and work with a 1.850" journal. The bearing shell would need to be right at .0825" thick . Thanks for any replies, Mark H.
You would be better off calling the bearing manufactures directly and talking with their tech guys.
Callico may also be an option for oddball bearings as they specialize in that stuff.
Clevite would be my 1st call.
What engine application??
Mummert
Post by Mummert »
Are you trying to put honda rods on a restrictor plate crankshaft.
Mummert Y-blocks
swampbuggy
Pro Power, it is a S.B.C. in a Super Late Model, the rods work with the 1.889" ( Honda ) journal . He has access to a Billet crank but the rod journals are the IRL size 1.850"
Mummert, i can't say i have ever heard a Crankshaft referred to as a " restrictor plate crankshaft ", would you explain what qualifies a crankshaft to be deemed a restrictor plate crankshaft ? Mark H.
