How much vacuum will three spur gear scavenge sections pull on a reasonably well sealed up SBC with a pan that isn't all that big?
Reason I'm asking is I swapped from a wet-sump setup with a vacuum pump to a four stage dry-sump setup and was wondering if I still needed to run my vacuum pump.
Would there be any conflicts between the dry-sump pump and the vacuum pump?
Also, what a good source for mandrels?
Dry sump pumps and vacuum
Re: Dry sump pumps and vacuum
Hello 408NOVA, i can't answer your question on your Pump but i can say BLP has a complete line of Mandrels. BLP in Orlando Fla. Mark H.
If it's sealed up good it should be able to pull at least 12" vac, likely more if the pump is not banged up.
https://www.enginebuildermag.com/2012/1 ... g-systems/
These guys are good at what they do: https://petersonfluidsys.com/index.html
Article that mentions using a vacuum pump with a dry sump system. https://www.motortrend.com/how-to/camp- ... il-system/
A phone call to these guys might be useful. https://www.aviaid.com/pdfs/z06retrofit_kit.pdf
For compactness and less stuff on the front of an engine, adding a 4th scavenge stage would be less total parts overall and one less drive belt and unique mandrel.
Now this is why I come here. This is very valuable information and I highly appreciate it!
