Question for the BBF guys......
PRH
Re: Question for the BBF guys......
Post by PRH »
Eliminator offers three varieties of this head.
This “BD” version has normal CJ intake ports, and the exhaust uses std Ford headers.
The overall height of the head is quite tall, and they use pretty long valves, which seems to be more for the version with the raised A460 style ports.
mudluvr2
Post by mudluvr2 »
I have a set of the CJHP that I ran years ago, they had 2.3" and 1.72" valves
PRH
Post by PRH »
What were the cam specs you ran with those heads?
The B3V BD is the CJ-HP head.
In theory, with a 2.30/1.72 valve combo you’d have had about .030-.035” seated valve-to-valve clearance.......depending on how deep the seats were cut and how thick the valve margins are.
mudluvr2
Post by mudluvr2 »
823/809 280/293@..050
PRH
Post by PRH »
Well, that’s more duration than what will be used with the ones I did...... so it should be good.
mudluvr2
Post by mudluvr2 »
Engine made 881 hp
PRH
Post by PRH »
mudluvr2 wrote: Sun May 22, 2022 12:23 pm Engine made 881 hp
This one won’t make that.
mudluvr2
Post by mudluvr2 »
I understand, just meant to say there pretty decent heads that are capable of some big hp with the right combination
PRH
Post by PRH »
They’re not much fun moving around in the shop from bench to bench though. 8)
mudluvr2
Post by mudluvr2 »
Nope lol
