KB hypereutectic pistons
Would you trust them on a iron head 350 with 10.5-1 compression and an occasional blast to 7k rpm's, on 91-93 octane pump gas? This will be just a fairly hot driver.
Re: KB hypereutectic pistons
If directions are followed on skirt clearance, ring end gap, and ignition timing, yes. Years ago out of a dare I built a 350 SBC with a 671 blower for a mini rod tractor puller using KB flat top pistons. It ran for 3 seasons before breaking a rod.
I asked that same question. Answers were kind of all over the map. But some support as posted above.
viewtopic.php?f=1&t=64901
Which ones are you looking at? There are a couple I'm aware of.
Kevin
91 and 93 octane are a lot different.. Which is it?
Can you set the top ring end gaps correctly?
Is your budget really that tight that you can’t afford forged pistons for what must be the worlds cheapest motor to rebuild?
It’s those occasional rpm’s to 7k that concern me.
Don’t forget that the load on those type of recuperating parts doubles with every 1000 rpm!
The pistons are .060 KB135's...18cc dish with 1.425" compression height. I bought them some 20 years ago for one of my own 388's but ended up changing directions on that build, so I've been dragging them around forever. With a 5.85 rod they will work in a 350.
I've got several sets of heads that I can use with these...56cc 601 castings, several sets of vortecs, and a set of ported 50cc chamber 200cc RHS heads that flow iirc 288@.550 or .600. I've been anxious to use these RHS heads, but it may be better to use one of the lesser heads with these pistons, and save the RHS heads for my roller block.
tuneup and tuneup and tune up.
I refuse to use no gap rings in anything. We'll Top Alchy maybe.
- af2
Get a set of 4032 and forget about asking. My sons 355 lasted 1 trip to the lake pinging and knocked the top land off with .030 ring.
GURU is only a name.
- af2
How do you find KB’s? Normally in the oil pan.
Seriously, gap the top ring correctly and don’t detonate the engine and they’ll last longer than you have interest in the engine.
- af2
The clue is don't go into detonation.rustbucket79 wrote: ↑Sun Apr 03, 2022 4:45 pm How do you find KB’s? Normally in the oil pan.
The heads and valves an exhaust is where you find the carnage.
- af2
Just got the jist!!!LOLrustbucket79 wrote: ↑Sun Apr 03, 2022 4:45 pm How do you find KB’s? Normally in the oil pan.
Wonder why all the fuss over hypers, darn near ever GM car and truck has had them since the late 90's. Sure don't hear anything about them other than the piston slap complaints on the LS hyper ones. My 5.3 has hypers and 250K noisy for the 1st 30 sec. after that the engine runs perfect. I say run'em but with KB you need to run more ring gap on the top ring.
- af2
The first thing is the fact the knock sensors?1980RS wrote: ↑Sun Apr 03, 2022 5:20 pm Wonder why all the fuss over hypers, darn near ever GM car and truck has had them since the late 90's. Sure don't hear anything about them other than the piston slap complaints on the LS hyper ones. My 5.3 has hypers and 250K noisy for the 1st 30 sec. after that the engine runs perfect. I say run'em but with KB you need to run more ring gap on the top ring.
I might be wrong but the ones I have seen are 4032..
