Fighting an off-idle bog and hoping for advice on next steps.
- Engine: 383 sbc, Comp XR276HR cam with 1.6 rockers
Car: 71 Corvette, 336 rear gear, Th400, 2400 stall
Electronics: HEI dist with MDS 6al box, VC302 vac adv can (providing 10* advance at 8-10” vacuum), Moroso HEI recurve kit.
Currently timed at 16* at initial, 35* total at 3200 or so. Recurve giving me ~19* centrifugal adv.
Showing 14” manifold vacuum in N, 12” in Drive.
Intake: Edelbrock EPS, Quick Fuel Brawler 650 dp.
- 70 primary jets, 74 secondary jets
6.5 power valve
31 squirter nozzles
70 outer air bleeds (idle), 28 inner air bleeds (secondaries)
Pink acc pump cams in #1 position
30cc acc pumps
What I’ve done:
- Checked floats at just below halfway on glass
Adjusted the acc pump arms to remove play
Checked transfer slots, look appropriately “square” - .020” showing
Put in 75 idle air bleeds to get fuel screws to be more in 1-2 turns out
Changed squirters from 31 to 35
Primary jets stayed at 70
Secondary jets from 74 to 75
- Bigger nozzles have not helped much
When adjust idle to around 14:1 afr with fuel screws, stumble very pronounced
When richen idle up to 12.0-12.5 or so stumble improves, but still there. Sometimes dips into 11s (gauge bounce around a lot)
Fuel screws with the new larger air bleeds are now at 1.25 turns out vs 3/4
Mid throttle afr is 12.5 – 13.0 - which is my target
Full throttle was 13.0 – 13.5, which is leaner than target. Will be swapping 74 secondary jets to 75s or 76s to get closer to 12.8 or so under heavy throttle
- Have ordered 37 nozzles
With 37s, will need hollow nozzle bolts?
With 37s, will need a 50cc accelerator pump kit? If so, both sides?
Should I swap out my pink cams for something else? Know screw position 2 on the pinks delays the squirt, which sounds the opposite of what’s needed here
If 37s don’t work, just keep going to 40s, etc.?
Something else I need to check?
