Cartridge roll’s
Cartridge roll’s
What brand cartridge rolls are made well like they use to be, as in glued along the whole rap length.
I just got a order of new ones ( and not cheap might I add!) only to find that there only glued up at the end and once that’s gone thru ( like in 30 seconds) the darn thing fly’s apart.
Thanks in advance!
Thanks in advance!
Re: Cartridge roll’s
I will look to see where I got the last batch, they last for a long time.mag2555 wrote: ↑Tue Apr 26, 2022 4:54 pm What brand cartridge rolls are made well like they use to be, as in glued along the whole rap length.
Thanks in advance!
It might be helpful to hear the brand names of the ones that come apart on contact with the job.
I have just got a few boxes of Merit rolls in 40 and 60grit
Last very well probably the best rolls I have used
These crappy 80 grit straight roll’s I have are from Cylinder head abrasives, so steer clear!
I buy the premium brand rolls in both blue and red with great results from cylinder head abrasive. Maybe you got a defective batch? Did you call vendor?
Carlquist Competition Engines
I will call them later and see what they can do.
I have had bad ones before that just plane ware out way faster then they should, but this defective glue up thing is very much pissing me off, especially since I purchased a quantity of 200 and not just a box of 50.
Thanks for the info!
I dont really use a lot of them but I get them from McMaster Carr and have really never had a problem with them. Dont know what brand they are.
I have got crappy ones and decent ones myself, sometimes it does not seem to matter on the brand, one batch is pretty good the next crap. I find that turning down the speed helps them live a lot better. It seems to me that many times they spin so fast that that the roll get hot and the glue melts letting them fly apart.
I only use sanding rolls on my cable driven motor so we are not talking excessive rpm’s
I use the standard abrasives ones, all the others I've tried either come apart, go 'blunt' & stop cutting or wear out real fast.
The SA ones are pretty good.
Only ones I get to live are Standard Abrasives. All the others blow apart early before being worn out. Includes Merit, Norton, and 3M I have tried
All I use are 707947 3M/SA's..
All I use are SE5/SE6 Aluma Burrs, on everything.
Made it real simple!
I also use Mcmaster Carr for cart rolls sometimes
