Does anyone know of an inline 9* Ford small block head?
I ended up with some pistons, and those are the specs for them.
Ford head question......
- nhrastocker
Re: Ford head question......
Ahhh thank you.
CFE ProKing.
The glidden’s 11.5 degrees I believe and the CFE is 10.
Either could be angle milled to 9. Foltz would probably machine whatever angle you want.
I thought somebody made a ford 9 degree.
Check with Bischoff.
The "N" heads were iron and 10 degree valve angle.
