Engine Diagnosis
Engine Diagnosis
Some time ago Ibuilt a engine for a customer, it was dyno tested and ran fine, the engine was installed in the car and would run for about 5 minutes good and then start running rough, the plugs would come out and look like, see picture.
1. Dist changed
2. 13.4 volts to the new HEI
3. Plenum clean
4. Carb not running a high float level
5. All 8 plugs look like this
6. Owner did assemble new MSD plug wires before installing the engine
Any help would be appreciated........
1. Dist changed
3. Plenum clean
Re: Engine Diagnosis
Buggered power valve?
Power valve too high? Like a 8.5 power valve with a big cam.
Plug is sorted, but not wet, so it's either a weak spark (that seems to be covered) or pig rich at low load.
Got a known good carb to throw on it to confirm or rule out a carb issue?
Does the HEI have the coil in the cap or is he using an external mounted coil ?
He has tried both.
The cam was 228 @ .050 and I believe we tested the same carb on the dyno, 770 avenger.KnightEngines wrote: ↑Fri May 13, 2022 8:22 am Buggered power valve?
Yikes, horrible carb, slap a 750 square bore pumper on it.vortecpro wrote: ↑Fri May 13, 2022 8:52 amThe cam was 228 @ .050 and I believe we tested the same carb on the dyno, 770 avenger.KnightEngines wrote: ↑Fri May 13, 2022 8:22 am Buggered power valve?
From time to time I have issues similar to this engine. First thing I do is slap a vacuum gauge on it, with a big cam bring up until the lope is gone, tells a lot about what is going on. Bouncing gauge valve train issues including flat camshaft, low vacuum retarded ignition timing, or just a poor running engine. then it gets a leak down and compression test to verify the base engine before I start trying other stuff. I also have and use an ignition scope also rules out a lot very quickly. Plugs look gas fouled so it is either rich, not enough compression to fire the cylinder properly, or very weak ignition. You never know what people have done. I built an engine for a guy, it sat for over a year waiting for the car to get painted. Called up said it would not start. He had put tape over the exhaust ports to keep out critters, BUT it left it on, and bolted the manifolds over the top of the tape. It simply would not pull enough air through the engine to start.
It starts and runs fine cold. It turns bad once the engine gets some heat in it. I'd be looking at stuff that changes with heat. Maybe a stuck heat riser. Maybe heat in the ignition module. Something is changing. Even valve lash.
Any gas smell in the oil?
I’m also on board with trying another “known good” carb, and/or ignition.
Anyone checked the voltage at the ignition?
Good voltage and a coil swap done, if it has 4 pin module, get another, maybe a napa TP45, check pick-up coil resistance hot, about 800 ohms, if memory serves, the old rule about carb problems turn out to be ignition may apply here.
Also don't forget heat compound under module, and ground strap/ wire to in cap coil if that applies.
Check metering block gasket is sealing the squirter hole to carb body. If that’s not an effective seal fuel will go into the pv vacuum chamber in the body. Cold might like the extra fuel but not warmed up. Just a thought.
