PipeMax Help Pipe Choices
I work on primarily Harleys and most of them have a 2 into 1 stepped header with merge style collector into a single baffled muffler, straight through. Can someone lead me to the proper choice for pipe type? TIA
Re: PipeMax Help Pipe Choices
checkout these 2 Files , should give you some insight ,
these 2 ProStock MotorCycle Files are included in PipeMax v4.70 installation :
ProStock_Bike_HD_VROD_160cid_Darin_Morgan_Flow_Numbers.PMW
ProStockBike_HarleyDavidson_VROD_160cid_George_Bryce_9600RPM.PMW
just change choice to :
Race Header • Multiple Steps • with Muffler
Merge Collector • Straight Tube Section
... and change Engine Specs to your Engine Specs
checkout notes inside PipeMax's NotePad Window
sime might be useful to you
