Parts for Keith Black gear drive
rickseeman
Post by rickseeman »
I have the cover for a Keith Black 426 Hemi gear drive but I need the guts. Everybody says the crank gears of different mfg's will interchange. I would think the cam gear might. The idler looks like a Donovan idler. Is there someone knowledgeable on gear drives that I could call? Thanks Rick
mag2555
Re: Parts for Keith Black gear drive
Post by mag2555 »
Since new gut's will cost a good bit anyway I would just get a new Milodon set up since if I recall right it fits in a stock timing cover with 5 minutes worth of rework.
ClassAct
Post by ClassAct »
mag2555 wrote: Thu May 19, 2022 8:44 am Since new gut's will cost a good bit anyway I would just get a new Milodon set up since if I recall right it fits in a stock timing cover with 5 minutes worth of rework.
The Milodon takes its own cover.
mag2555
Post by mag2555 »
Not from what I see in my catalog!
ClassAct
Post by ClassAct »
mag2555 wrote: Fri May 20, 2022 5:56 am Not from what I see in my catalog!
If it’s a Hemi or a BBM it takes a cover. Anything with a cheap stamped tin cover has to have a cast aluminum cover. How do you fix the idler to the cover if it’s tin? And the cover isn’t thick enough to allow for the idler to be fixed to a plate. That would be a cover like the SBM, Pontiac, Ford etc. Anything with a timing cover that isn’t stamped tin can used a fixed idler gear drive that fits under the OE cover. Otherwise it’s has to have a cover.
ClassAct
Post by ClassAct »
Big block chrysler gear drive from Milodon.
mag2555
Post by mag2555 »
The idler is on a steel plate that they say bolts to the block.
ClassAct
Post by ClassAct »
mag2555 wrote: Fri May 20, 2022 11:35 am The idler is on a steel plate that they say bolts to the block.
That’s for a small block.
