rod oil clearance
rod oil clearance
has anyone run .005" oil clearance on a 2.375" rod journal successfully?
° alt+0176 °
Re: rod oil clearance
You need to fix the clearance. You're not going to have a happy engine with that much clearance. Even Top Fuelers don't run that much clearance with a 70 grade oil. It gets sketchy past ~.0035" as the ability of the oil film, regardless of viscosity, to keep the journal from going too eccentric is greatly diminished. Peak load carrying capacity for a journal bearing is ~.001" per 1" of journal diameter which is why that's the industry standard. I wouldn't even think of trying to make .005" clearance work. I'd be getting the clearance tighter.
ordered a new set of rod bearings. not sure how i ended up with the clearance i did with all new parts, but i suppose that is how things are these days.
fingers crossed that the next set are better.
° alt+0176 °
how did you determine clearance ?
What were the Journal diameters and housing bores.
2.375 journal
2.380 id of bearing snapped into rod and torqued
measured a couple different spots with telescoping gage and mics. double checked with decent calipers. (we are looking for thousandths after all...)
there was a couple tenths here and there, but it was a solid .005 on all.
° alt+0176 °
Not a fan of snap guages. I suggest you buy a piece of plastigauge as a pretty accurate check of what you are seeing.
- af2
I know of few dozen blown Alky that run .009"..............................RDY4WAR wrote: ↑Thu May 19, 2022 9:39 am You need to fix the clearance. You're not going to have a happy engine with that much clearance. Even Top Fuelers don't run that much clearance with a 70 grade oil. It gets sketchy past ~.0035" as the ability of the oil film, regardless of viscosity, to keep the journal from going too eccentric is greatly diminished. Peak load carrying capacity for a journal bearing is ~.001" per 1" of journal diameter which is why that's the industry standard. I wouldn't even think of trying to make .005" clearance work. I'd be getting the clearance tighter.
GURU is only a name.
- af2
And I wouldn't on a steel rod deal,af2 wrote: ↑Fri May 20, 2022 3:36 pmI know of few dozen blown Alky that run .009"..............................RDY4WAR wrote: ↑Thu May 19, 2022 9:39 am You need to fix the clearance. You're not going to have a happy engine with that much clearance. Even Top Fuelers don't run that much clearance with a 70 grade oil. It gets sketchy past ~.0035" as the ability of the oil film, regardless of viscosity, to keep the journal from going too eccentric is greatly diminished. Peak load carrying capacity for a journal bearing is ~.001" per 1" of journal diameter which is why that's the industry standard. I wouldn't even think of trying to make .005" clearance work. I'd be getting the clearance tighter.
