Gm Fast Burn vs Ebay 200 Dart Pro 1 Copy
Re: Gm Fast Burn vs Ebay 200 Dart Pro 1 Copy
Thanks Steve yes for sure, I noticed he liked playing with the Vortec port shape side of things, that’s why I originally targeted him.
I hope all is well with Randy331
You know Zing, it would appear that any work done on the GM heads, perhaps because they are still actively used in the racing circles here (USA rather than Canada that is) that the relevant mods remain under wraps. Maybe yes, maybe no?Zing wrote: ↑Tue Jun 14, 2022 5:17 pm Thanks for the advice fellas, yes I follow Weigartner Racing on YouTube, I’ve watched his videos on the KMJ Assault heads he does for his sisters car. Yes very easy and good flow numbers.
Eric seems a good guy and his videos are very informative.
I was sort of hoping there may have been a chance for the GM Fast Burn heads with similar mods, not the bigger valve but the rest etc.
Looks like I may have to pass on the Gm Fast Burn head deal, and purchase some Ebay Dart copies.
I previously sent a message to Randy331 asking his advice before I posted this post, as I have seen he has modded a few sets, and was hoping for his advice?
It’s a shame to pass up USA cast genuine Gm products, for Ebay China generics simply not from a price point of view, but the performance is just not there
But, Weingartner has some solid results with Dart copies and he addresses what might be the problems with an offshore (aka Chinese) casting. There might be something in that for you.
Best of luck and I'll be interested in your progress. Please post up on where you end up.
Kevin
I talked to him a while ago,he is wrapped up in restricted 2 barrel dirt engines at the moment .
I bet with the 770 Holley fixed right it would have made more than 450hp
I have a set of unported Fastburns, they were on an engine in a Nova that I bought. Engine is apart and they will go on the flowbench pretty soon to see where they are at, then they will get ported... will see how they turn out. I have the Randy 331 thread saved. Would have been nice to see the port mold he created, that would have been a big help.
Definitely mate not much info on porting them.
I’ve just made the decision I’m going with the Ebay Dart1 Platinum copy’s
Way more info and I know I can make them work for my application
Well how things change in 25 minutes
I’ve just bought both styles of cylinder heads and I’m going to the flow bench to back to back test them.
I’m intrigued by the Fast burn for some reason.
One pair of heads will be back on the market?
The bench will tell
Gm Fast Burn vs Ebay Dart Copy
Ding ding round 1
Which head will survive the flow bench cull?
The bench will tell
Ding ding round 1
Matt,Zing wrote: ↑Wed Jun 15, 2022 12:18 am Well how things change in 25 minutes
The bench will tell
Ding ding round 1
If you decide to sell fastburn heads let me know and I would like to buy them from you.
I am not far from you
No worries Steve I will stay in touch.
You ever seen a set?
No I have not,always wanted a set after seeing what Randy did.
He done 2 sets,the second set he made the the throat the minimum cross sectional area instead of the pushrod pinch.
Basically what happens is if you make everything bigger it pushes peaks higher in the rpm range.
Those heads to buy here are pretty expensive so that was another issue as well.
I have half dozen sets of Dart heads and a pair of TFS camel back alloys so I should not buy any more heads but I like the vortec architecture but never worked on a vortec head hence me having no relative information for you .
What heads do you have you want to swap the fast burns for
I like the Vortec deal on heads the factory 062 906 are an awesome factory head for performance considering, I’ve played with those.
It’ll be interesting to have a look at a pair of Fast burns in the flesh as I think they should be a 062/906 on steroids hopefully
Do you have any links to Randy331 work on these Gm heads?
What suburb are you around Brissy?
have had some of the ebay heads come thru but they were for ford. I did not flow them but i know they were a dart copy and seemed to hear from an old contact that they flowed roughly the same ( 260ish at .600?). Id wager the sbc ebay heads are not much different from there dart equivalent . Now what I can tell you about the heads I saw recently 1. Quality was not a concern for manufacture , seats were not properly installed, one or two had trash where seat should register. 2. more casting flash then i would care to see. 3. valve sizes were off........so at the end of the day your looking minimum seats redone and a light clean up of chamber and ports. but you might end up with something nice afterwards. I know guy who brought heads in payed under 200 a head bare, think he came out good on it but your mileage may vary.
I am at BURPENGARY so not far from you.Zing wrote: ↑Wed Jun 15, 2022 8:05 am What heads do you have you want to swap the fast burns for
I don't really want to swap or sell anything as parts are hard to get lol.
Steve, if you play with the fast burn heads can you post up some info on them?
Pro question poster.
Gotta get them firstBob Hollinshead wrote: ↑Wed Jun 15, 2022 8:33 pm Steve, if you play with the fast burn heads can you post up some info on them?
