I have a set of fully ported 440 -1 heads that have been cut³quite a bit, and one failed and blew a head gasket. I had the failed head welded up and resurfaced. Compression was 15.3/1, methanol, 550 cubes made 926 hp. Fourteen dyno pulls, then failure on drag strip pass number seven. I want to drop compression to 14/1 and probably run a couple degrees less timing to make the whole deal live a long life.
My question is, what effect will a . 027 below deck
And . 060 thick or thicker gasket do to power? Any other problems?
Effects of lowering c. r. With thicker head gaskets?
1965 dodge Dart, 549 cu in wedge, 8.60 at 156 mph best. 2905 lbs, soon, 8.40s!
