Exhaust question Wth is this?
chevyfreak
Re: Exhaust question Wth is this?
Post by chevyfreak »
Walter R. Malik wrote: Fri Jul 22, 2022 9:58 pm
IF one side is longer than the other or slightly different in diameter, it could be about noise frequency control of some kind.
That is the only thing I can figure.
Same as what 3B said, i can only think it was done as experimenting or so that it can be said its their (brand name) design. Or maybe the only left overs was some bends.
Anyway, thanks for al that answered, the funny type, serious type and the different type that i possible misread the responce.
Chevy freak.
Bowtie for life
ELS
Post by ELS »
did someone use that exhaust section as a driveshaft? :D
mag2555
Post by mag2555 »
Might this look familiar?
malibuguy79
Post by malibuguy79 »
I believe its to adjust exhaust resonate frequency when in a cylinder deactivation mode. Ive seen it before I want to say that was the premise. It has been a while however.
dannobee
Post by dannobee »
One thing's for sure, if you put that thing on your circle track car and won, by the next weekend, every other competitor would have their version of it on their exhaust.
Curtis Mc
Post by Curtis Mc »
chevyfreak wrote: Fri Jul 22, 2022 2:47 am
Schurkey wrote: Thu Jul 21, 2022 6:39 pm Making the competition waste time, money, effort, and enthusiasm trying to reverse-engineer the thing, when they'd be better-off dealing with their own combination rather than monkey-see-monkey-do with your stuff.
I'm not in competition with anyone, nor challenged anyone on this forum.
I asked a question, to find an answer, I never said i'm gonna do it, i asked a question.
Sorry if you feel it's a waste of your time and effort, you are not forced to answer every topic. If you decide to read it and went on to another topic it's minimal of your time and effort and gives you more time for your own stuff.
You decided to use more of your time and effort to give a reply.
Chevyfreak.
Hey Chevyfreak, I think you missed his point. This would be an old "racer" trick, that I am sure you have run across in the past where a racer/team tried something, found it didn't work, and it didn't hurt either, which when another team sees it, has them scrambling to replicate it thinking there was some advantage to it. Vizard has shared these stories, and I have heard some similar stories off the record many years ago. I don't think that comment was towards you.
F120
Post by F120 »
vortex generator
In-Tech
Post by In-Tech »
Just as a test I Y'd the pan-e-vac from the exhaust to the valve cover and intake manifold(of course plugged internally) sure as S$%t the next week there were at least 2 cars popping and banging around the track. :lol: :mrgreen: =D>
-Carl
juuhanaa
Post by juuhanaa »
Minimal flow loss flexible pipe design? Needed incase of collision etc when the typical flex joint isnt enough.
juuhanaa
Post by juuhanaa »
ELS wrote: Sat Jul 23, 2022 9:35 am did someone use that exhaust section as a driveshaft? :D
:D
chevyfreak
Curtis Mc wrote: Tue Aug 02, 2022 12:43 pm
Chevyfreak.
Hi, i did realise that as it was pointed out earlier, was my biggest plunder that week, had a week from hell that week. After it was pointed out i saw what was meant and that i just read it wrongly at that time, I do apologise for it and to mr Schurkey, for me having a dumb moment.
Chevyfreak.
Bowtie for life
ptuomov
Post by ptuomov »
That looks like a $8,473.00 factory exhaust option from Porsche.
Put Search Keywords Here
GARY C
Post by GARY C »
Super_Stock wrote: Fri Jul 22, 2022 3:23 am Acid.. or Ludes...
Be one with the air... :)
Dan Timberlake
Post by Dan Timberlake »
download/file.php?id=30477&t=1
Is that spring from a real vehicle ?
juuhanaa
Post by juuhanaa »
Dan Timberlake wrote: Mon Aug 08, 2022 12:26 pm download/file.php?id=30477&t=1
I google, yes and it looks even worse on "live" 😀
