I think it's an exercise in futility because ultimately cylinder pressure and burn rate / quality dictate what geometric compression ratio works with kind of fuel. Intake valve closing does as well, especially in regards to Miller Cycle engines where IVC is before BDC (this is what modern F1 engines are).HQM383 wrote: ↑Mon Jul 25, 2022 2:33 amSo considering Harold’s statement above and this from another thread:
Is an attempt to calculate dynamic compression an exercise in futility if using swept volume without knowledge of density and mass?A volume of air can exist at various pressures, which will determine density, and therefore MASS.
An internal combustion engine depends entirely on AIR and FUEL MASS, never volume.
For volume to have any meaning, we must know its density. Volume is a static metric, a space.
I guess my point is Dynamic Compress Ratio (as most people know it from magazines and hot rodding books) only works for these old type engines where there are again, "rules of thumb" based on nothing but experience. If you look at pressure traces on a bent crank V8 with a single carb, some cylinders make more pressure than others and some make more pressure at a different crank degree than others. And what cylinder changes with rpm as maldistribution and pressure wave interference in the manifold changes as the cylinders come in and out of tune due to varying geometries of the intake length (and this is not adding g forces to it). Furthermore, on a pushrod engine, the valve events are going to get shorter with rpm due to stiffness issues. Billy Godbold has shared good data on this for all to see, so IVO, IVC, etc. are all variable. Billy has talked about making everything stiffer and fixing things on the Spintron, and the engine builder has to relearn what events work because what they thought worked, was really just what they found to work without realizing it was just a compensating value to manage flex they didn't know / understand they had. Furthermore, when you look at today's modern high tumble designs, with 12.5-13:1 compression on bores as large as 4" or more (and turn 13,000rpm in the case of Ducati) on pump gas, you realize they're not using IVC to bleed pressure, but they are doing it with better engine management and good in cylinder motion. Obviously 2 valve engines would struggle with this as they are swirl base (except a hemi type chamber, but that has other problems), but 2 valve engines can have compact combustion chambers which help (take a look at a modern NASCAR chamber for example). Then add better cooling systems, piston oil squirters, etc. and things get "it depends" really fast.
But consider above, and then think about what DCR tells you where you just consider swept volume and IVC to tell you, vs all the things that effect cylinder pressure in a running engine above, and I'm not sure what it tells you other than people have correlated it through testing to some octane threshold for a very specific type of engine, which makes it a rule of thumb for only a certain type of engine that author / builder has experience with.
