Figure if anyone would know it would be you guys. I have a broken egr tube on a 96-00 L29 454 gen VI BBC. gm discontinued the part over a decade ago, used tubes sell for 350-454 on ebay. I looked at it and the fitting on the manifold and intake is just a -12 jic with 3/4" opening. have any of you ever used dom hydraulic line and bent it to replace an egr tube? stuff is rated at 3500 psi, and can be bought in stainless or mild steel. flares easily to 37* and the fittings are available, bends easy. and I can wrap it with header wrap. any reason it wouldnt hold up in this situation? I cant bring myself to spend over 400 bucks on a used part. was hoping for a cheaper repair option. any suggestions?
or maybe one of you guys put one in a chevell and have the stock manifolds and egr laying around at a reasonable price?
egr tube repair
Re: egr tube repair
Do you have to pass an emissions test?
Re: egr tube repair
no, but im trying to do this engine swap with stock ecu, and was hoping to avoid having to pay hp tuners credit and patch cable price just to disable it. and its just a truck that will be used for some towing, so id like to not make the 12-13 mpg any worse than it already is.
Re: egr tube repair
Do you have a picture of the part ? I have a complete 2000 engine in my next door unit that might have it on it. I am going to be using the long block for a marine build so I wont need that part.
Re: egr tube repair
it connects to the driver's side manifold and runs to the intake, right behind the egr valve. Ideally both fittings and the line would be great Bill K. Drew a black line around it. If you have it let me know. Can send payment anyway you prefer.
Re: egr tube repair
Is the original tube "corrugated" so that vibration won't crack it?
I'd be a bit concerned about using ordinary tubing that's not designed to flex.
Re: egr tube repair
100 bucks for credits to delete it. I don’t think hyd hose would deal with the heat long term. If you don’t have anyone local to tune I’ll do it for you on the cheap as a member to member if you can’t run one down.
