Where can I get these?
3/8 barb necked down to 1/4. I’ve looked around a good bit, no luck so far. See yellow circle
Re: Where can I get these?
A couple of options I can probably make work (with a little rubbing, but that’s ok).
But I’d rather have this (yellow arrow). 3/8 flare barb to 1/4 press fit tube. The throttle body I want to put it in doesn’t have much meat to work with.
Might be worth giving these guys a call if you haven't already
https://allcarbs.com/?v=920f83e594a1
https://blp.com/cart/index.php?main_page=index&cPath=65
I haven’t yet, but I will. ThanksHQM383 wrote: ↑Tue Aug 09, 2022 6:12 pm Might be worth giving these guys a call if you haven't already
I have several out there which I have made.ArizonaGuy wrote: ↑Tue Aug 09, 2022 3:45 pm 3/8 barb necked down to 1/4. I’ve looked around a good bit, no luck so far. See yellow circle
Get a proper 3/8" tube and a 1/4" tube with a very short collar of 5/16" tube ... using some silver solder with a natural gas torch, fuse them together.
If you go down Walter's bundy tube route, you could make the 3/8" end barb with a brake tube flaring tool by only doing the first step.
