If going to Methanol, do I need to raise the CFM as well?
patrickonb
Post by patrickonb »
Hello Gang, I have another dumb question for y'all...
Building the 433 BBC, all info says I should use a carb in the 800-850 cfm range. If I decide to go
to Methanol or E85, and the fuel now needs to be doubled (or there about), do I then also need
to raise the CFM rating of the carb?
Thanks,
Patrick
mag2555
Re: If going to Methanol, do I need to raise the CFM as well?
Post by mag2555 »
No.
You could use bigger intake ports because since your now going to have twice as much fuel vapor taking up room that was air when running gas.
You could well use more lift also.
Elroy
Post by Elroy »
In theory, i would think you could get away with a smaller carb on alcohol fuels.
CamKing
Post by CamKing »
No need to go bigger on carb, or ports.
When you switch to Methanol, it will lower the temp of the intake charge thru the carb, manifold and ports. The cooler charge will increase the air density, which more then makes up for the area lost to the added fuel.
patrickonb
OK, thanks for the reply's, I appreciate it!
Patrick
Walter R. Malik
Post by Walter R. Malik »
patrickonb wrote: Wed Aug 10, 2022 1:58 pm Hello Gang, I have another dumb question for y'all...
Thanks,
Patrick
NO ... but, if you already are using a very large carb with gasoline, you may need to go to a smaller air flow rated carb because that large carb may not be able to flow enough fuel for its airflow rating, when using alcohol; even after being modified for alcohol.
patrickonb
Walter R. Malik wrote: Wed Aug 10, 2022 9:29 pm NO ... but, if you already are using a very large carb with gasoline, you may need to go to a smaller air flow rated carb because that large carb may not be able to flow enough fuel for its airflow rating, when using alcohol; even after being modified for alcohol.
Ahh yes, this does make sense!! Thank you.
Tom68
Post by Tom68 »
433ci. 850cfm @ 20.4 inH20 would be a small carby if it's got good heads and a cam wouldn't it ?
Walter R. Malik
Tom68 wrote: Thu Aug 11, 2022 1:32 am
It is all about IF that carburetor is able to supply enough fuel for the amount of air it can flow.
gregsdart
Post by gregsdart »
What will the airflow be at launch, and also top end? You need a carb that will work at both ends. I would think an 850 to 950 cfm for a 750 hp build,,,,,,,
1965 dodge Dart, 549 cu in wedge, 8.60 at 156 mph best. 2905 lbs, soon, 8.40s!
Alaskaracer
Post by Alaskaracer »
Not mentioned but noteworthy:
alky is nearly 50% by volume, oxygen. That's why you need to run roughly twice as much as gasoline. Methanol carbs tend to be smaller than gas on the same application so they have a bit stronger signal to the boosters, which helps pull the fuel. Carbs and methanol work, work well, but in my somewhat limited opinion, the best setup to run methanol is mfi. Simple, easy to tune, and much less headache than a carb......
Mark Goulette
Authorized Amsoil Retailer
prairiehotrodder
Post by prairiehotrodder »
Coloradoracer wrote: Sat Aug 13, 2022 10:31 am Not mentioned but noteworthy:
What kind of MFI do you like ?
Alaskaracer
I run a Killerron's setup, and it's the best thing I ever did for my program. Enderle is also another huge one, and in wide use everywhere. Both work equally well.
Mark Goulette
