BBC 3946074 OpenChamber RoundPortExhaust Flow Numbers
2.250/1.880 Valves 3/8ths Stems
.... kept the original "As Run" Valves , they were in very good shape !
Flow Numbers should be Posted by Thursday or Wednesday nite
Info :
these Heads had damage in Chambers and Decks
and i managed to redo the Chambers so you cannot tell.
The Decks on 1 Head will be perfect ,
the other Head is more damaged and it will have some 'dings' left
but luckily the dings are not where Headgasket fire-ring-seal is located .
I've milled the Decks -0.008" off ,
can't really mill the Decks more than -0.008" to get rid of all the dings ,
the top of Intake Seat angle is already at the Deck surface with just -0.008" milled off so far
and it would probably take another +0.030" mill to completely remove all the dings
but then i would need to sink the Valve Job on all 8 Intake Seats
"As Run" Pics :
Re: BBC 3946074 OpenChamber RoundPortExhaust Flow Numbers
Cylinder # 3 Bad Port Direction 4.500 Bore Fixture No Exh Flow Pipe
will Flow test the Cylinder# 1 GPD later tonite + Post Flow Numbers
will also Flow test Exhaust Port with a Pipe to compare
and will re-Flow Test both Cyl#1 and Cyl#3 Intake and Exhaust Ports on a 4.280" Bore Fixture
just to compare 4.500" -VS- 4.280"
- Super_Stock
Jeebus, it looks like the Hulk took a dump on your inlet port !!LOL
comparing a 4.280" Bore Flowbench Fixture -vs- 4.500" Bore Flowbench Fixture
also comparing without an Exhaust Flow Pipe -vs- with an Exhaust Flow Pipe
