Linetoline break in
Linetoline break in
Has anyone that uses the linetoline skirt coating ever broken in the coating other than the way they instruct us to.
Re: Linetoline break in
I have had pistons coated, properly broken in. The coating must be gradually worn in, I assume to avoid literally tearing it loose from the piston skirt due to too fast of a run in. It comes on the pistons about . 0025 too thick so it can be worn in gradually and soak up oil in between cycles. If you try and break it in in one heat cycle, I assume it will fail .
1965 dodge Dart, 549 cu in wedge, 8.60 at 156 mph best. 2905 lbs, soon, 8.40s!
Would not the break in for the L2L and proper ring break in be the opposite of each others needs ?
If you would coat pistons and the coating would not survive the ring break in process what exactly would the point be of the coating?
I haven't used the line to line coating , only have read positive reviews but I all I can picture is it embedding into the cross hatch ???
