Now .025 x .240
Enlarging a transition slot
Re: Enlarging a transition slot
I actually tried that first, before starting this thread. Once I got it figured out and fixed it, I ran it with the calibration as it was. It was (predictably) fat at idle and on the tslots since I’d put such big IFRs in it while chasing the wrong tail. I’ve since corrected all of that, and it now runs like a champ
It looks to me that if you reduced the clearance, opening on the secondaries, the engine would have to draw more air past the primaries and you would have to open them a bit which would put them closer to where you want them.
- jmarkaudio
Cheap small flat file from Harbor Freight grind the wide sides off leaving the thin side with teeth.
Mark Whitener
www.racingfuelsystems.com
____
____
Now why didn’t I think of that? Great idea, thanksjmarkaudio wrote: ↑Mon Sep 12, 2022 1:31 pm Cheap small flat file from Harbor Freight grind the wide sides off leaving the thin side with teeth.
Yep!
Looks good.ArizonaGuy wrote: ↑Thu Sep 01, 2022 12:59 pm Now .025 x .240
