Valve springs dimensions cross reference
williamsmotowerx
Post by williamsmotowerx »
Looking for a valve spring list by size and a oem part number or where used
BillK
Re: Valve springs dimensions cross reference
Post by BillK »
Stock or performance ??? Most of the stock replacement parts suppliers have that in the back of their catalogs. I know SBI does and so does Melling. What exactly are you trying to find ??
hoodeng
Post by hoodeng »
Those sheets are old copies of Crane spring lists. They are on A3 so i can't do a scan on them, the photos are it.
Another is https://www.precisionengineparts.com/downloads go to the complete catalog xlss and go to springs, it will give a full list of their springs in dimension and application.
I am sure there are a bunch of others, these are two i use.
Cheers.
Turbobuick6
Post by Turbobuick6 »
Are we looking for OE springs or performance springs?
rebelyell
Post by rebelyell »
https://pioneerautoinc.com/downloads/dl ... atalog.pdf
Valve Springs: tabular listing via OD begins at (in pdf file) about page 83 thru about 90.
Rather comprehensive specs for each spring, although No OEM PNs referenced.
Hundreds of different valve springs.
williamsmotowerx
Best one yet Rebel.
Nothing close for my application. It's a oddball motor, would have thought something would be close out there.
learner1
Post by learner1 »
rebelyell
Post by rebelyell »
williamsmotowerx wrote: Tue Sep 20, 2022 1:08 pm Best one yet Rebel.
Some 25 years ago I was quite familiar w/the "old" KL of Chicago; dunno if still in the spring business. KL once did short runs.
Contact K L Spring & Stamping Corporation
Phone: (773) 583-7200
Fax: (773) 583-7201
Email: sentinal@earthlink.net
Address
3323 W Addison St
Chicago, Illinois, 60618-4303
*** there remains several other spring makers in Chicago ***
modok
Post by modok »
sbi catalog
BillK
Post by BillK »
Can you tell us what dimensions and pressures you are looking for ?
williamsmotowerx
OD .816"
ID .568"
OAL 1.807"
WIRE DIA .122"
105lbs @ 1.04"
Just looking for 10 to 15lbs more across the range. If new spring was 115 to 120 @ 1.04" that would be fine.
It's a diesel turbo application that will see a lot of miles.
