The two pickups pictured are for an AMC V8. One factory, the other a Canton and their pan.
How do you estimate the two match up in effectiveness?
The obvious it the size of the opening. The tubes are similar shape and ID size.
Bell compared to the rectangle cavity? I imagine the opening in the factory is adequate for the tube ID so is a bigger hole better or advantageous with essentially the same tube?
I ask because Moroso is making a new replacement higher capacity oil pan for an AMC V8 as of now, to be used with a factory pickup. They can change that at this point and offer a pickup to go with the pan.
Oil pickup tube
Re: Oil pickup tube
I would say there would be no difference in performance except the one with fewer bends and/or a larger tube would be better.jcisworthy wrote: ↑Thu Sep 29, 2022 9:52 am The two pickups pictured are for an AMC V8. One factory, the other a Canton and their pan.
Re: Oil pickup tube
AM one is smaller screen area and can be cleaned easily, all welded construction.
OEM one is larger to account for poor maintenance, sludge in oil, and to function for 100K+ miles... all while being as cheap to produce as possible.
Re: Oil pickup tube
The Moroso pickup needs to be .250 away from the pan. The OE AMC pickup needs to be touching the pan. You shouldn’t have to crank the pan down with the bolts, but it should be an interference fit. They both will work.
Re: Oil pickup tube
They both are to be gapped.
From the factory, the stock AMC pickup had a plastic button in the bottom of the screen to prevent them from being sucked to the bottom of the pan. The plastic didn't always go the distance but initially they were there initially
I figured they were both comparable and the factory should work fine with the new pan
