SBC connecting rod ID
redvetracr
Post by redvetracr »
can anyone ID the manufacturer of these rods, they are marked PD with a 4 digit 58XX number which I assume is weight in grams....thanks in advance!!
redvetracr
Re: SBC connecting rod ID
better pics
In-Tech
Post by In-Tech »
By the rod bolt, they appear to be Eagle ESP H beam rods.
-Carl
BillK
Post by BillK »
You might want to call Eagle just to be sure. I have not used that many Eagle rods but all that I remember said Eagle on the bolts, not ESP. But they may have changed.
ec1
Post by ec1 »
I think Eagle rods always have the double cut groove down the inside of the beam. These appear to be a single radius cut like scat or just about everything else h-beam. Although the esp should be an eagle bolt?? Maybe it's a Chinese copy of a China rod?
