USAC Midget Exhaust Header specs
Mostly interested in lengths. It seems engine builders are still favoring very long 4-1 primaries, and just curious if they're really as long as they look, or are just exaggerated because of how small the cars are. I know the Honda K24's are near 380bhp @ 9800rpm and 260lb-ft of torque at around 7800rpm. They certainly seem long for that rpm range, but I know they're searching for driveability as well, so I don’t think they’re around the second harmonic, but look pretty close.
Re: USAC Midget Exhaust Header specs
Seems like most all dirt cars use long tube headers. I think it's like you say for drivability. Smooths out the power band. At least that's my thoughts.
On the dyno shorter tubes will make more peak power.
http://www.youtube.com/watch?v=itIITBanJDs
http://www.harshmanauto.com
Second harmonic should work over a narrower band.
The WoO builders have been experimenting with 4-2-1’s on and off over the last ten years or so. Some run them, some don’t, but I would have expected them to catch on more in the Midget ranks, and always wondered why you still see the long primary 4-1’s still.
https://frontstreet.media/2021/04/02/th ... -learning/hoffman900 wrote: ↑Mon Oct 03, 2022 9:07 pm Mostly interested in lengths. It seems engine builders are still favoring very long 4-1 primaries, and just curious if they're really as long as they look, or are just exaggerated because of how small the cars are. I know the Honda K24's are near 380bhp @ 9800rpm and 260lb-ft of torque at around 7800rpm. They certainly seem long for that rpm range, but I know they're searching for driveability as well, so I don’t think they’re around the second harmonic, but look pretty close.
The linked article says the headers are 1 7/8" off the head stepping to 2" for the rest. Scaling from the photos, I get about 18" total primary plus the port - say 3.5" - Total 21.5". That is probably about right for 7,800 rpm with that small ID.
Before the step I get about 4" + port 3.5" = 7.5 long"
Thanks. I was too busy to put it in CAD and scale it to match. I suspect it's some as what I said, they're small cars, so appearances are deceiving.gruntguru wrote: ↑Mon Oct 03, 2022 11:52 pmhttps://frontstreet.media/2021/04/02/th ... -learning/hoffman900 wrote: ↑Mon Oct 03, 2022 9:07 pm Mostly interested in lengths. It seems engine builders are still favoring very long 4-1 primaries, and just curious if they're really as long as they look, or are just exaggerated because of how small the cars are. I know the Honda K24's are near 380bhp @ 9800rpm and 260lb-ft of torque at around 7800rpm. They certainly seem long for that rpm range, but I know they're searching for driveability as well, so I don’t think they’re around the second harmonic, but look pretty close.
If that’s a 2” pipe my painted on eyes say that looks more than 9x diameter
You crazy Man say 1 7/8" and 2" ID or OD doesnt matter small?gruntguru wrote: ↑Mon Oct 03, 2022 11:52 pmhttps://frontstreet.media/2021/04/02/th ... -learning/hoffman900 wrote: ↑Mon Oct 03, 2022 9:07 pm Mostly interested in lengths. It seems engine builders are still favoring very long 4-1 primaries, and just curious if they're really as long as they look, or are just exaggerated because of how small the cars are. I know the Honda K24's are near 380bhp @ 9800rpm and 260lb-ft of torque at around 7800rpm. They certainly seem long for that rpm range, but I know they're searching for driveability as well, so I don’t think they’re around the second harmonic, but look pretty close.
I have been told my 2 liter Renault with 29,6mm exhaust valves and 1450mm2 exhaust port at manifold flange is hogged out
-juhana
Yeah, I wouldn’t call it 1 7/8” od small with that tubing, at that power level. NASCAR ran that off the head when pushing 870bhp and WoO 410ci’s run 1 7/8” od tubing off the head and they can make 1000bhp (but useable power, they’re in the mid 900s). That’s about 115-120bhp/cylinder.juuhanaa wrote: ↑Sun Oct 09, 2022 12:12 pmYou crazy Man say 1 7/8" and 2" ID or OD doesnt matter small?gruntguru wrote: ↑Mon Oct 03, 2022 11:52 pmhttps://frontstreet.media/2021/04/02/th ... -learning/hoffman900 wrote: ↑Mon Oct 03, 2022 9:07 pm Mostly interested in lengths. It seems engine builders are still favoring very long 4-1 primaries, and just curious if they're really as long as they look, or are just exaggerated because of how small the cars are. I know the Honda K24's are near 380bhp @ 9800rpm and 260lb-ft of torque at around 7800rpm. They certainly seem long for that rpm range, but I know they're searching for driveability as well, so I don’t think they’re around the second harmonic, but look pretty close.
-juhana
Always cracks me up seeing street cars / bracket cars with 2.25” od primaries on 650-750hp engines.
Yeah, but aren't those high hp engines stuck in terms of torque, while Honda makes torque over a wide rev range?hoffman900 wrote: ↑Sun Oct 09, 2022 12:18 pmYeah, I wouldn’t call it 1 7/8” od small with that tubing, at that power level. NASCAR ran that off the head when pushing 870bhp and WoO 410ci’s run 1 7/8” od tubing off the head and they can make 1000bhp (but useable power, they’re in the mid 900s). That’s about 115-120bhp/cylinder.juuhanaa wrote: ↑Sun Oct 09, 2022 12:12 pmYou crazy Man say 1 7/8" and 2" ID or OD doesnt matter small?gruntguru wrote: ↑Mon Oct 03, 2022 11:52 pm
-juhana
My 2l pump gas Renault junk produces an unofficial 1.5ft lbs/cid at 4000rpm using a total of about 27in long 4-1 headers stepped 9cm from the cylinder head and 38mm to 41.5mm. Those 4-1 headers also do not have collector choke shown in the Honda picture and i have yet to experience an oversized ID.
-juhana
