10027633 Super Duty 2.5 Block
10027779 3.25" Stroke Super Duty Crankshaft
10031323-Cast-Iron head with EGR
I picked the Car up in 2015 and have been ever so slowly taking the engine apart.
I bought a Aluminum head off Ebay in 2015 shortly after buying the Fiero, Pontiac PN 10049801 — Super Duty Four High Port Special Aluminum Cylinder
Head
I don't really care to run the Iron head, its heavier, has EGR ports that I don't care for, and didn't flow what I expected when I tested it, I'm a little young to have been around these motors when they were being used in racing, and no one I know has messed with 4 cylinders. So I'm just reading internet information, and magazine info that I have found. I have the Build Guide Pontiac Published when they released the motor.This version of Pontiac’s Super Duty four-cylinder aluminum cylinder head's
are designed for maximum-effort competition engines. The intake runners
and water jackets are raised .670" to improve flow. In the Special High Port
casting, the two center intake ports are moved .800" closer together to
straighten the path to the valves. Both heads’ rocker cover rails are raised
.300", and the exhaust ports are raised .600". The valve centerlines are
relocated to unshroud the valves, and the rocker stud holes are moved to
match the new valve locations. The valve seats will accept 1.94–2.08" intake
valves and 1.60–1.625" exhausts. The combustion chamber volume is 67cc.
Technical Notes: Valve guides are supplied but not installed. A template is
provided for redrilling headers to fit the revised exhaust flange bolt pattern.
An intake manifold must be fabricated to fit the High Port Special's port
spacing.
I have only seen a photo of one of these heads fully assembled, and it had Jesel shaft mounts on it.
My block is the 3 journal bearing cam block, it appears from what I see Pontiac went to a 5 bearing cam block with rollers bearings later in their production. The engine right now has a hydraulic flat tappet cam, but I've got some rust on the lobes, and have no clue the specs. I see Isky still lists several cams for these engines in their catalog, so I think will run their one of their hyd cams. I will street drive the car, autocross it, and track it at Road Amerrica or Autobhan, I think a circle track spec cam would work well for that.
I had emailed Jesel in 2015 about a shaft rocker system and was told KPS-02716 is their pro series for this head.
What I am wondering, if anyone is familiar, because the valves and stud holes are relocated on this head, will I need offset lifters to run this head with my block?
Am I locked into a Jesel Pro rocker system, or like other 151 Pontiac heads, can 1.7 or 1.8 BBC roller rocker work with this head?
I placed my iron head (322 casting) studs and guide plates on the head this morning, and the 801 heads pushrod holes were about 3/8" further away from the stud that the guides were, which makes me wonder if this head was designed around a different rocker arm. ISKY does list their larger Roller cams with a 1.55:1 ratio.
Does anyone have experience with this head or motor? I have yet to see anyone make one of these heads work on a street motor.
