Seat cutter for 40 degree exhaust
I'm doing a valve job on a set of 5.2 ford voodoo heads and just found that the exhaust seat is 40 degree. Does anyone have a part number for a cutter bit that will work on these seats?
Re: Seat cutter for 40 degree exhaust
37.5 is all I can know about, near that angle.
This, that's what I would do
If you send them a drawing, Serdi and Goodson will make a cutter bit for you. I expect that Newen will too.
Jim McMahon
Heads1st
http://www.heads1st.com/
Heads1st
