BBC rear main leak
In-Tech
Re: BBC rear main leak
Post by In-Tech »
Most of the LS/LT stuff says to install dry on the rubbing surface. Hopefully one of these guys/gals here can provide some insight. I always used to lube everything.
-Carl
Warp Speed
Post by Warp Speed »
In-Tech wrote: Thu Nov 24, 2022 12:36 am Most of the LS/LT stuff says to install dry on the rubbing surface. Hopefully one of these guys/gals here can provide some insight. I always used to lube everything.
LS has a Teflon sealing face so yes, dry.
I always worry about the dust seal but it doesn't seem to care.
