You will need to raise the port roof to match the 1206 gasket as the out of the box 300-25 is very close to the 1205. That's what I did one my 300-25.Monza355 wrote: ↑Tue Jan 10, 2023 5:20 pmHow does the 1206 gasket fit the 300-25 strip dominator ?ChopperScott wrote: ↑Tue Jan 10, 2023 12:07 pm For the Holley fans, here is a new out-of-the-box 300-25 Strip Dominator with a 1205 gasket...
SBC Intake Manifolds: Creating Another List.
Re: SBC Intake Manifolds: Creating Another List.
1206...1980RS wrote: ↑Tue Jan 10, 2023 8:36 pmYou will need to raise the port roof to match the 1206 gasket as the out of the box 300-25 is very close to the 1205. That's what I did one my 300-25.Monza355 wrote: ↑Tue Jan 10, 2023 5:20 pmHow does the 1206 gasket fit the 300-25 strip dominator ?ChopperScott wrote: ↑Tue Jan 10, 2023 12:07 pm For the Holley fans, here is a new out-of-the-box 300-25 Strip Dominator with a 1205 gasket...
6901...
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
I was surprised after looking at Edelbrock castings for so many years. Some were really terrible and didn't fit correctly.ChopperScott wrote: ↑Tue Jan 10, 2023 8:28 pmWhat surprised you concerning the quality of casting?
I'll head out to the garage and take a few pics.
I haven't handled enough Edelbrock manifolds to make a comparable judgement. I've read that the later Super Victor 2925 is a much better casting. As far as Holley is concerned, I can't say I'm too impressed with the castings out-of-the-box, but with a little time and effort, they could prove to be nice pieces.rfoll wrote: ↑Wed Jan 11, 2023 9:30 amI was surprised after looking at Edelbrock castings for so many years. Some were really terrible and didn't fit correctly.ChopperScott wrote: ↑Tue Jan 10, 2023 8:28 pmWhat surprised you concerning the quality of casting?
ChopperScott wrote: ↑Thu Jan 12, 2023 11:52 am As far as Holley is concerned, I can't say I'm too impressed with the castings out-of-the-box, but with a little time and effort, they could prove to be nice pieces.
This one is a Mopar, raised runner manifold, modified for small block chevy, that a friend of mine had on his 434...
This is his current intake manifold...
-12 rails, nice
-Carl
-Carl
Like button, where's the WOW button.ChopperScott wrote: ↑Sat Jan 14, 2023 7:01 pm This is his current intake manifold...
Man he must be revving that high.
Mike is proficient at tuning Holley EFI with nitrous. He'll be going with a blown alcohol, ProCharger combo next time out.Tom68 wrote: ↑Mon Jan 16, 2023 12:39 amLike button, where's the WOW button.ChopperScott wrote: ↑Sat Jan 14, 2023 7:01 pm This is his current intake manifold...
He runs the car to the 1/8 mile on a 275 radial...
He must have let off the throttle on that run buy the 1/8 to 1/4 mph. Nice time though.ChopperScott wrote: ↑Mon Jan 16, 2023 11:30 amMike is proficient at tuning Holley EFI with nitrous. He'll be going with a blown alcohol, ProCharger combo next time out.Tom68 wrote: ↑Mon Jan 16, 2023 12:39 amLike button, where's the WOW button.ChopperScott wrote: ↑Sat Jan 14, 2023 7:01 pm This is his current intake manifold...
Yep. By my reckoning it takes about 3 seconds to cover the eighth mile at 145 MPH.
Kevin
He definitely cruised to the 1/4. It would have spit out the bottom end if he stayed on the throttle. He tells people it's a 327.
I didn't want to give up on the Holley 300-110. Even though I tried it with two sets of 1206 gaskets (2 x .060), I decided to order a set of of 1266 gaskets (.120). After further inspection, I'm confident it will work. I will just need to be careful with the roof on the one set of runners when matching.
That intake works great if you want your TQ to peak higher than your hp. For his procharged methanol deal, it won't matter though. Might actually help.ChopperScott wrote: ↑Sat Jan 14, 2023 7:01 pm This is his current intake manifold...
