SBC Intake Manifolds: Creating Another List.
ChopperScott
Re: SBC Intake Manifolds: Creating Another List.
Post by ChopperScott »
steve cowan wrote: Thu Nov 24, 2022 7:07 am Looks good Scott,
How much taper do you work on for your application.
On my 383 engines that turn around 7000rpm I look at approx 3/4"
That manifold is way too small for my application. It’s an old outdated design. I wouldn’t use it on anything larger than 327 cu in.
As far as taper work is concerned, I just blend and finish without reinventing the wheel.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
Post by F-BIRD'88 »
Holley 300-261. or 300- 264 (vortec version)
New holley single plane offering.
Lower) carb height like a Perf RPM or Vic Jr.
Allows optional carb spacer play.
Looks very similar to a Vic JR.
Post by F-BIRD'88 »
The Hi Tech Tork Link intake manifold has tuned runner length to make good mid range mid upper power and torque.. Much like a cross ram or long runner tall tunnel ram but with a single carb.
Hard to beat the visual impact.
https://bangshift.com/wp-content/upload ... elink3.jpg
1980RS
Post by 1980RS »
F-BIRD'88 wrote: Thu Nov 24, 2022 2:53 pm The Hi Tech Tork Link intake manifold has tuned runner length to make good mid range mid upper power and torque.. Much like a cross ram or long runner tall tunnel ram but with a single carb.
I have one hanging on the garage wall, I should test it sometime. Definitely a car show talking item.
Tom68
Post by Tom68 »
F-BIRD'88 wrote: Thu Nov 24, 2022 2:39 pm Holley 300-261. or 300- 264 (vortec version)
No injection bosses.
skinny z
Post by skinny z »
That Holley Vortec intake is on my hit list.
Kevin
Post by F-BIRD'88 »
Tom68 wrote: Thu Nov 24, 2022 8:03 pm
There are versions that do have injector bosses.
Holley.com
Post by F-BIRD'88 »
skinny z wrote: Thu Nov 24, 2022 8:18 pm That Holley Vortec intake is on my hit list.
I am curious about that one too.
All the other vortec head single planes are quite tall carb height.. This one gives you options.
Monza355
Post by Monza355 »
1980RS wrote: Thu Nov 24, 2022 4:23 pm
That would be an interesting test for sure! I would love to see the results compred to both single and dual plane intakes you’we ran on your combo before.
Tom68
Post by Tom68 »
Monza355 wrote: Fri Nov 25, 2022 3:13 am
Whilst it could be called a dual plane, it isn't a 180 degree manifold, so it won't come close to a dual planes bottom end, may better a single plane up to 5000 RPMish, but it will get dusted beyond 6500.
skinny z
Post by skinny z »
F-BIRD'88 wrote: Thu Nov 24, 2022 10:07 pm All the other vortec head single planes are quite tall carb height..
Speaking of which, what's out there besides the usual suspects from Holley and Edelbrock?
There's also Speedmaster.
Kevin
Tom68
Post by Tom68 »
skinny z wrote: Fri Nov 25, 2022 4:15 pm
One I bought back in 2014. Procomp, lower runners are pretty small.
Tom68
Post by Tom68 »
Stock Vortec must be half a chance.
ChopperScott
ChopperScott wrote: Mon Nov 21, 2022 7:51 pm I’ll be on that Team G…
skinny z
Post by skinny z »
Tom68 wrote: Fri Nov 25, 2022 4:31 pm
Is that ProComp a single plane? When you mentioned lower runners, I thought no.
Kevin
