Total engine airflow heads?
bthomas
Post by bthomas »
Anyone used tea for sbc heads? I know their ls and sbf heads are considered top notch.
Looking at the 23* 230cc head the published mid lifts are crazy good.
https://totalengineairflow.com/product/ ... nder-heads
amc fan
Re: Total engine airflow heads?
Post by amc fan »
I have used them. They CNC port the 215's. They even made the chamber a little bigger at my request to fine tune the compression.
I was surprised the flow sheet they sent with the finished heads was even better than the advertised specs.
Racer71
Post by Racer71 »
I ran their sbf heads way back in the day. I believe tooley had something to do with them back then I could be mistaken though. I wouldn’t think they could be too bad as good as their other stuff is.
Lloyd klem
Post by Lloyd klem »
No disrespect but that is not impressive for that size head and bore flowed on.Ex side is weak.220 head shows way better ex side.We have set of trick flow 220s angle milled /ported and 2.100 valve.We are similar below .400 but 12-17 cfm better everywhere above that.We put ex port plates on and moved port up and over and did 270s on ex side.It is ran on e93 so we wanted good ex port in it.I believe our heads are 236 cc now.We have single carb tunnel ram and our .550 to .700 numbers are very similar to tea through manifold.I would say they did a very conservative port.jmo
Post by F-BIRD'88 »
Looking at the flow test charts it is interesting thst the big flow is concentrated in the street/strip friendly valve lift zone. .400" to.550/.600" area. As opposed to some other racing heads where the flow is way up at very high valve lifts .,600"-.700" +.
On these the port works where the valves are going to be opening up to on a street oriented engine.
Right where it needs to be.
Should work well.
Just an observation.
Lloyd klem
F-BIRD'88 wrote: Thu Nov 24, 2022 11:25 am Looking at the flow test charts it is interesting thst the big flow is concentrated in the street/strip friendly valve lift zone. .400" to.550/.600" area. As opposed to some other racing heads where the flow is way up at very high valve lifts .,600"-.700" +.
Should work well.
Yes I agree to some extent.If you are doing a ported 230 cc head on 4.125 bore fixture you are looking for more than street friendly heads.The stuff we consider street here is full effort in each part we purchase.I look heavy at .450 to .600 numbers when I do my own heads.Thats how I pick my cams from those numbers.But if I'm doing a 230ish cc head and have 305 cfm or 319 cfm at at .500 lift for say ,I want the bigger number always in our stuff.I like to see my numbers carry well past .700 also so my deal doesn't fall on its face and carry past intended rpm peak.This is jmo but ..
amc fan
Post by amc fan »
I found the printout for the TEA heads 230cc they ported for me years ago. I consider them street strip 4.125 bore with 1 3/4-1 7/8 step header
.2-149cfm int 130.9cfm ex
.3-223.9 190.4
.4-274.9 234.3
.5-305.9 257.9
.55-313.1 266.1
.6-316.2 269.4
.7-320.3 276.7
This is the website print out for what I consider race head 18-degree heads
Their 275 18-degree flows:.4 -281cfm int 225 ex .5 -328cfm int 255ex- at .6- 370cfm intake 273 exhaust at.7 390cfm int-281 exhaust
295 18-degree flows:.4-286 .5-340int,285 ex-at.6 383int,305 ex .7 402 int,313 exhaust
WeingartnerRacing
Post by WeingartnerRacing »
I will go ahead and kick someone in the nuts. I do not believe it flow close to 270s at .400 on my bench. It’s very unbelievably. On either of my benches there have only been three 23 sbc heads that have hit 270cfm at .400. Two of them were raised runner the other was huge. I have flowed many heads from many manufacturers it’s just doesn’t happen. I’m sure some day it will come in and I can share real numbers.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
amc fan
Post by amc fan »
Hey Eric, what do the AFR 235 SBC Eliminator heads flow @.4 on your bench? They advertise them at 270 cfm.
What make and model bench does AFR use? What bench does TEA use? Do you think they are using the same make and model Flow bench?
I take people at their word. I have no reason to believe I am being lied to. Not everyone on Speed Talk has a flow bench so we take what we are given in good faith.
WeingartnerRacing
The afr 235 does
.400-254
.500-290
.600-312
.700-317
Afr 245
.400-253
.500-291
.600-312
.700-321
I have a superflow 750 that reads a tick higher at peak and Saenz d680
You can see what many heads flow on my you tube channel. It’s called Eric Weingartner
Afr has a superflow I can’t remember if it is the 600 or 750
Eric Weingartner
918-520-3480
www.wengines.com
swampbuggy
Post by swampbuggy »
Thank you Eric W. for taking the time to share . Mark H.
n2omike
Post by n2omike »
amc fan wrote: Sat Nov 26, 2022 1:33 pm I take people at their word. I have no reason to believe I am being lied to. Not everyone on Speed Talk has a flow bench so we take what we are given in good faith.
Advertised/published flow numbers are almost always highly optimistic... If you look at advertised Chinese numbers, they are downright blatant lies. lol
bthomas
Post by bthomas »
WeingartnerRacing wrote: Sat Nov 26, 2022 11:56 am I will go ahead and kick someone in the nuts. I do not believe it flow close to 270s at .400 on my bench. It’s very unbelievably. On either of my benches there have only been three 23 sbc heads that have hit 270cfm at .400. Two of them were raised runner the other was huge. I have flowed many heads from many manufacturers it’s just doesn’t happen. I’m sure some day it will come in and I can share real numbers.
That’s why I asked here, figuring someone has actually flowed their heads. It seemed like a high number to me, but I also didn’t see them pumping it 20cfm either. Especially when their ls heads are so highly regarded. :-k
af2
Post by af2 »
amc fan wrote: Sat Nov 26, 2022 1:33 pm Hey Eric, what do the AFR 235 SBC Eliminator heads flow @.4 on your bench? They advertise them at 270 cfm.
I would like to go further on the 235 RHS heads I ran and did very well un touched.
GURU is only a name.
WeingartnerRacing
I’m going to eat some crow here but I got a set of trick flow 230cc Cnc ported heads in and this is what they did on the Saenz d680
.4-261
.5-296
.6-310
.7-305
.8-307
.9-309
1.0-310
So no 271cfm but I flowed it on the superflow 750 and it went 269cfm@.400 324cfm at .9
Really strong at .4-.5 after that meh. I would really like to test this head on the dyno mule or the idea of more low lift flow makes more power than peak flow. I think there is a balance but where does it switch.
Eric Weingartner
918-520-3480
www.wengines.com
