juuhanaa
Post by juuhanaa »
steve cowan wrote: Thu Dec 01, 2022 2:47 am
juuhanaa wrote: Thu Dec 01, 2022 2:25 am When you tell a 4-cylinder guy (with half the cylinders in use) that he needs a spacer.
-juhana
Maybe a nice radius would help
:D
Yea, i think so. Im not sure how many spacers or radiuses i need, so to play it safe, im thinking to doubling up.
-juhana
1980RS
Post by 1980RS »
KnightEngines wrote: Thu Dec 01, 2022 1:26 am I did this coz I'm stupid & couldn't buy the required manifold.
440 Chrysler victor intake chopped up & welded back together to fit an AMC 401:
Now that's talent right there. Fantastic work.
Bigchief632
Post by Bigchief632 »
Think this one is big enough?
Lloyd klem
Post by Lloyd klem »
Nice to use billet runners and leave a nice bell radius in plenum around each port.
Erland Cox
Post by Erland Cox »
Dry flow?
Erland
Lloyd klem
Erland Cox wrote: Thu Dec 01, 2022 1:44 pm Dry flow?
Erland
Mfi,
Runner nozzles
juuhanaa
Post by juuhanaa »
Erland Cox wrote: Wed Nov 30, 2022 4:36 pm The secondary ramming wave cancels out the higher cylinder pressure before TDC and both prevents reversion, lets the intake cycle start
a little earlier and cleans the combustion chamber of residuals which means that som loss out the exhaust is necessary. .
It is a positive wave, next we need a negative so it is more or less canceled out during overlap.
Next big depression comes from exhaust before EVC and piston after that.
Not earlier waves.
Erland
Now that we got to the dry flow manifolds...
What earlier waves? You said it yourself that a wave is reflected by the change in area, so its the same thing that goes back and forth between the runner entry and the valve, that we can calculate the frequency for, and that makes a difference between IVO and IVC.
-juhana
Erland Cox
No. There is no frequency for it during valve open.
Outgoing wave velocity is the local speed of sound minus the flow velocity.
Ingoing wave velocity is the local speed of sound plus the flow velocity.
Forget the earlier waves, everything starts with the energy from the exhaust and the piston, IVO to IVC.
That energy will be used up during valve closed, IVC to IVO and then it starts over again.
If you look in the diagram you can see the difference in degrees from top to bottom of the waves between
what happens during valve open and valve closed.
That is because of the flow velocity during valve open and no flow velocity during valve closed.
There are a lot of residual waves but they are weaker and thinking about them clouds everything and makes it even harder to understand.
Erland
juuhanaa
Post by juuhanaa »
How much value would it give to show an example using a simple calculation for the thing vs pressure trace from various rpm using a simulation software vs chassis dyno?
When the calculator is from USA, simulation software from South Africa, and engine from Finland?
-juhana
Erland Cox
Vanniks software would show the curves and what happens with different tapers and lengths.
The dyno would show what the result was.
Erland
Lloyd klem
Erland Cox wrote: Thu Dec 01, 2022 6:26 pm Vanniks software would show the curves and what happens with different tapers and lengths.
Erland
There we go ,the more we do the math the less we know! Experience,r&d is everything.I have read so much expert knowledge that is no where near what goes on.People think they find something,and that's cool.Most things do not duplicate enough for us to understand.Thats why I only do what intrigued me ,I will never work on anything again that someone thinks they figured out.What happens at one rpm does not at another.The only guys that impress me have general knowledge of race engines,can produce a decent Dyno sheet and bring that to life at the track etc!!
juuhanaa
Post by juuhanaa »
Erland
You miss the point when we disagree about the thing and wether the thing has a frequency during valve open. Doing a calculus for the thing and finding it using the tools i suggested, would then not give you value.
-juhana
hoffman900
Post by hoffman900 »
Lloyd klem wrote: Thu Dec 01, 2022 11:56 am Nice to use billet runners and leave a nice bell radius in plenum around each port.IMG_20221127_191150943.jpgIMG_20221127_190651537.jpg
Ever play with a divider down the middle?
It takes some correlation, but EngMod4t is fantastic for this stuff, but mostly is looking at dry flow. However, I put one of the virtual pressure sensors at the booster location and that’s revealing. Remember, carbs work off of pressure differentials and will work both ways as well… people who work with individual runner carburetors know this well.
JES
Post by JES »
Wow, those pictures are great. Thanks Chad, I can see to some degree how you are making the runner length more equal. You and others have shown me much by pictures and dialogue that I can understand.
Tom68
Post by Tom68 »
hoffman900 wrote: Thu Dec 01, 2022 11:38 pm
Which picked up 7kw on the V10 but didn't work on the V8, it says they divided the front cylinders on the V8 and encouraged interference on the rear, or something to that effect. Flat plane crank anyways no doubt.
http://www.f1-forecast.com/pdf/F1-Files ... P2_10e.pdf
