I spent a little more time with the AFR Eliminator...
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
[quote="Lloyd klem" post_id=931018 time=1669577123 user_id=35995]
Here is a pic of imo the most common mistake made.And getting paid for the hours to correct this is tough.Guy paid for this once and now I get to redo it correctly Look at fair left runner which is number 3.Its a shorter runner than number 1 next to it.It has a bunch more csa than number 1 runner.So I can only go up on number 1 to get csa and taper fixed.It won't have much of a round radius left going into the roof.I will have to add 1 inch spacer and incorporate into that.This will get plenum opened a bunch with shear plate also.IMG_20221127_120751130.jpg
[/quote]
Thanks. From how you explained it I can see exactly what you are saying. The entire port was slowed down, but the high velocity that was created, was in the wrong spot.
[/quote]
I'm sure you've seen my posts about this one. Any pics of the ports? What gasket are you using?SpeierRacingHeads wrote: ↑Tue Nov 29, 2022 4:21 pm Dorton 300-110 I just finished up today. My favorite manifold.
[quote=rfoll post_id=931164 time=1669737471 user_id=10266]
I'm kind of late to the party but I have been using a different method for port match that only uses a gasket as a spacer. I think the articleport matching.jpg was from Vizard. There was mention of builing up with epoxy and I may need to do this. Any recommended brands?
[/quote]
That look's like Visard. I have used this many times, and works reasonably well. Lately, I have been painting on Prussian blue and bolting down the intake. I also learned it from something I seen on the web.
[/quote]
1207ChopperScott wrote: ↑Fri Dec 23, 2022 12:05 amI'm sure you've seen my posts about this one. Any pics of the ports? What gasket are you using?SpeierRacingHeads wrote: ↑Tue Nov 29, 2022 4:21 pm Dorton 300-110 I just finished up today. My favorite manifold.
Nice work Chad. I don't care what anyone else says, your burr finish just plain works for me. After doing that I have never seen such clean plenums, runners and port runners in all my years of running engines.SpeierRacingHeads wrote: ↑Fri Dec 23, 2022 12:23 pm1207ChopperScott wrote: ↑Fri Dec 23, 2022 12:05 amI'm sure you've seen my posts about this one. Any pics of the ports? What gasket are you using?SpeierRacingHeads wrote: ↑Tue Nov 29, 2022 4:21 pm Dorton 300-110 I just finished up today. My favorite manifold.
Hat's off to you. That's a lot of work!..
Are you seeing anything worthy-of-note regarding "transient" throttle response or shift recovery with the burr finish? Anything noticeable just normal street-driving?1980RS wrote: ↑Fri Dec 23, 2022 1:13 pmNice work Chad. I don't care what anyone else says, your burr finish just plain works for me. After doing that I have never seen such clean plenums, runners and port runners in all my years of running engines.SpeierRacingHeads wrote: ↑Fri Dec 23, 2022 12:23 pm1207ChopperScott wrote: ↑Fri Dec 23, 2022 12:05 am
Nope, just a cleaner are in the intake and ports since I have started doing that to my stuff, oh and better ET and MPH as the car ran better when I leaned it down form prior testing.RevTheory wrote: ↑Fri Dec 23, 2022 2:28 pmAre you seeing anything worthy-of-note regarding "transient" throttle response or shift recovery with the burr finish? Anything noticeable just normal street-driving?
I don't know what burr Chad is using, but if I tried finishing like that, I'd probably ruin the manifold. On that AFR, I used a ball head carbide burr on the plenum floor into the runners, 60 grit in the runners, with a cross and blend buff at the ports and the leading edge of the divider walls.1980RS wrote: ↑Fri Dec 23, 2022 3:58 pmNope, just a cleaner are in the intake and ports since I have started doing that to my stuff, oh and better ET and MPH as the car ran better when I leaned it down form prior testing.
But isn’t the cleanliness more of a tuning thing ? I have an as cast edelbrock intake on a race engine. And it looks like it’s never been used when I remove the carburetor and look down the plenum.1980RS wrote: ↑Fri Dec 23, 2022 3:58 pmNope, just a cleaner are in the intake and ports since I have started doing that to my stuff, oh and better ET and MPH as the car ran better when I leaned it down form prior testing.
The coarse burr finish activates the boundary layer so that less fuel clings to the walls.
Off throttle te walls dry and finer finishes need more accelerator enrichment,
Erland
Erland
This might prove interesting:
Weingartner, AFR, Pro-Filer.
https://www.youtube.com/watch?v=perj8vKW47E
Kevin
That's pretty much what it's band aiding if it helps. I've had intakes with the carb sitting right on the manifold, pull the carb, and you can see fuel stain from the fuel wash on the walls and around the turn from the plenum entry into the runners. Put a 2 inch spacer on, engine gains a bunch of power, and the stains disappear. What happened? So many variables to just say this is the end all be all mod.Monza355 wrote: ↑Fri Dec 23, 2022 5:23 pm
What happens if your running a flat hood and can't run a spacer?
What happens if rules don't allow you to run a spacer?
What happens if the spacer causes issues on the shift?
Some say band aide. Some say tuning aide.
I have stories of guys going faster and they would let you call it anything one chooses!
