frnkeore
Post by frnkeore »
Another thing I note about ported plenums, is that most of the dividers, come to a fairly sharp point.
I've studied aerodynamics a bit, and at subsonic velocity's, a full radius works better than a sharp leading edge. Is this just a case of the need for CSA out weighs turbulence?
juuhanaa
Post by juuhanaa »
As far as radiuses, dry flow + wet flow = bigger picture.
Lloyd klem
Post by Lloyd klem »
frnkeore wrote: Sat Dec 03, 2022 2:14 am Another thing I note about ported plenums, is that most of the dividers, come to a fairly sharp point.
Some instances you have 2 ports flow way different and you can make leading edge work to advantage..Run it and look at where fuel trails or coloring is and adjust from there.Everything I work on csa and overall shape is king.Everything else is way below that.
brentry
Post by brentry »
just want to understand all the things I see on a dyno.
What about things you see in sim.
Havnt you ever chased something on the dyno you saw in sim. I know guys that have and found that power. Didn't happen 1st try.
ChopperScott
Post by ChopperScott »
AFR 4811PM…
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
Lloyd klem
Cut m in half boys.
Lloyd klem
Don't be afraid to do some testing and some of your own math on what long runner should have for more csa,taper etc.Most manifolds it should be pretty visible difference.You never learn if you don't try.
NXBOY
Post by NXBOY »
Any Ford bigblock guys here?? We need more help with manifolds hen any of you all lol.
NXBOY
Post by NXBOY »
Lloyd klem
Just finishing up manifold for 1300 hp 11 deg BBC dart heads.Guy got a little wild and cut some good gutters into walls and above port roof entrances.Had to resize runners and some epoxy work to fill his trenches.
mt-engines
Post by mt-engines »
PROFILER HITMAN 2.600 carb
Lloyd klem
mt-engines wrote: Sun Dec 04, 2022 11:02 am PROFILER HITMAN 2.600 carb
That has some area.Guessing that not for pickup pulling a camper.lol
Joe-71
Post by Joe-71 »
BBFs are available. The High Riser before and after flow figures, RPM before and after flow figures. Joe-71
Joe-71
1980RS
Post by 1980RS »
Here's my Dart intake I 've messed around with a few times, it's never performed very well at the track. Even my Air Gap makes more power.
ChopperScott
