289 EMC Heads Part 3
Mummert
Post by Mummert »
More work with a unique twist.
https://youtu.be/eD1OdESca4Y
Mummert Y-blocks
Mummert
Re: 289 EMC Heads Part 3
Post by Mummert »
Anyone make it to the end. FE's can use the same trick.
Mummert Y-blocks
frnkeore
Post by frnkeore »
Yes, can you explain the spark plug modification, in more detail and what plug did you use?
Mummert
Post by Mummert »
The plug is 1" reach from a modern powersports vehicle, available at most motorcycle shops. The adapters are the trick. Making so that they can installed and semi permanent or quickly removable for a/b testing is a little more difficult. Our test versions were a little tricky to deal with but doable. To sell them we did some re engineering. A production run wasn't made for reasons stated in the video.
Mummert Y-blocks
dondon
Post by dondon »
this might be a dumb question, but because I will be bored this winter, I plan on porting some 65 289 heads and put chev valves in them. is it worth the time and effort to pour aluminum in the exhaust crossover? It is just something to do. I plan on having them flowed when their done
Mummert
Post by Mummert »
It depends on who you talk to. Bill C has told me they are not seeing any difference on the dyno one way or the other. It looks right and been done many times over the years. If you have ability and want the challenge I'd say do it. If you don't do it I wouldn't sweat it.
Any of you FE guys pick up on the spark thing.
Mummert Y-blocks
Walter R. Malik
Post by Walter R. Malik »
dondon wrote: Mon Nov 28, 2022 8:51 pm this might be a dumb question, but because I will be bored this winter, I plan on porting some 65 289 heads and put chev valves in them. is it worth the time and effort to pour aluminum in the exhaust crossover? It is just something to do. I plan on having them flowed when their done
With a closed exhaust system it will make no difference.
If getting an open header exactly in tune, it could mean a few horsepower.
blackford
Post by blackford »
Mummert wrote: Sun Nov 27, 2022 9:49 pm Anyone make it to the end. FE's can use the same trick.
I like that spark plug mod. I've got a pair of 351w DOOE heads that flow almost 250 cfm (243 @ .600) and i'd love to add that mod to them. It also takes up a couple of CCs of space to raise compression.
65 Mustang FB, 331 custom built with 289 H beam rods and 383W piston, 282S cam, Ported Maxx 180s, T5z, 9" 3.89 gears. ~460HP@6500
2013 Corvette 427 Convertible daily driver
Mummert
Post by Mummert »
I'm looking at making some Ill let interested people know when I get some info.
Mummert Y-blocks
frnkeore
Post by frnkeore »
Put me on the list, please.
Walter R. Malik
Mummert wrote: Wed Nov 30, 2022 1:23 am I'm looking at making some Ill let interested people know when I get some info.
I used to buy a like item from Garret Machine when they were in business.
Those plug adapters worked great in FE engines and early 385 big blocks, as well.
Mummert
Post by Mummert »
What kind of spark plugs did they take?
Mummert Y-blocks
frnkeore
Post by frnkeore »
Mummert, what spark plug # are you using?
BLSTIC
Post by BLSTIC »
How much timing would doing something like that take out?
There's some very long-reach long-projection spark plugs out now so it seems like you could put the spark almost wherever you want it if you can get the heat out of it.
