Cubic inch horsepower at given RPM
Is there a calculation or calculator or rule that would dictate an RPM difference where peak horsepower/torque would happen in the RPM range based off of a difference in cubic inches?
Example: 496 chevy with matching parts has peak power
at 6300.
468 chevy with matching parts has peak power
at 6800 to make the same hp as 496
at 6300.
Re: Cubic inch horsepower at given RPM
I think i found it on Wallace.
Estimate RPM That Peak Horsepower Will Occur????
Enter Head Air Flow in CFM (at 28 in. of water):???
Enter Engine CID: ???
Assuming I enter same head flow for each cubic inch calculation I "think" this will work.
That's not always the result depending on what else is limiging the engine and what is creating its peak.rapidride2 wrote: ↑Tue Nov 29, 2022 4:03 pm Is there a calculation or calculator or rule that would dictate an RPM difference where peak horsepower/torque would happen in the RPM range based off of a difference in cubic inches?
at 6300.
An 80s style long runner manifold is gunna limit the revs of peak horsepower on any size motor.
I see. But if all parts are the same except cubic inches shouldn't the rpm difference be accurate.
Im basically trying to see how much more or less two different cubic engines make the same power at.
Such as how much more rpm i would have to turn a smaller displacement to achieve same power of a larger displacement.
- Stan Weiss
Maybe Mike Jones will way in. But I don't see the 2 engines wanting the exact same cam.
No.
The larger engine will pull more vacuum from the same heads, so the CFM @ 28" input isn't correct.
you are assuming that torque increases linearly with displacement
Horsepower = Torque x RPM / 5,252
496 500ft-lb at 6300rpm is 600hp
468 463ft-lb at 6800rpm is 600hp
Studebaker V8 heads are intake CFM limited to an approx max of 220. I ran a DynoSim of the OEM displacements and made the same max horsepower, but at different RPM. IIRC,
224" - 8300 RPM
259" - 7300
289" - 6800
305" - 6300
And yes, of course, each required a specific cam profile to make that horsepower.
224" - 8300 RPM
259" - 7300
289" - 6800
305" - 6300
If the heads, cam, etc. are too small, the bigger engine will make very little more power.
If the heads are too big, the increase will be closer to the displacement ratio.
NEVER linear as described.
Okay, I was taking into account that each engine was an optimized combination.
