Burn patterns on piston and chamber
Spark plug wetting seems to be a issue for a lot of early OEM type cylinder heads.
The fuel used here was MS109
I am interested in opinions on what guys think is happening in the burn process.
Re: Burn patterns on piston and chamber
Do you have a back cut on the intake valve?
50 degree seats and no back cuts
You could pull a bunch of fuel out of that.Your pistons don't have near enough coverage imo.Need to get some texture too them.
Yes,you are leaving a bunch of power behind there.Im no flat top piston fan at all .That being said even on alky piston should have 95 percent plus coverage if your engine is sealed and your valve job is correct.
With burr finish in ports and chamber.
Should I try burr finish on the piston too?
Erland
Hottest part stains first, hold it full load at 6000 for several minutes and I think it'll look a lot different.steve cowan wrote: ↑Sat Dec 03, 2022 2:48 pm 20221203_182359.jpg20221203_180151.jpg
Curious on what to look for and which direction one should take when looking at burn patterns.
I assume this is an engine you built so I don't have to ask you about texture in the intake manifold or ports. The fuel is dropping out of suspension and you need less quench area. A lot of people thru the years have added fuel coolers . Cold air, hot fuel is a key. And yes, I agree with others, you are extremely rich. Some of this could be the fuel suspension problem.
-Carl
-Carl
If my stuff looked that bad I would consider it and I don't burr finish anything.Jmo.It is consistent tho across whole layout.Looks way over fueled/oily compared to what I'm used to seeing.I would work on my valve job and really look at my honing procedure in a mess like that.I would check what ring edges and ring lands look like also.Erland Cox wrote: ↑Sat Dec 03, 2022 6:14 pm
Erland
Good point tom,Tom68 wrote: ↑Sat Dec 03, 2022 6:20 pmHottest part stains first, hold it full load at 6000 for several minutes and I think it'll look a lot different.steve cowan wrote: ↑Sat Dec 03, 2022 2:48 pm 20221203_182359.jpg20221203_180151.jpg
Engine was dynoed for Max power.
When looking at this chamber and piston one has to consider some street miles and driving around pits as well.it looks to me like the engine was cold so to speak.
The carbon is not a build up but like a stain if that makes sense.
Super Stock engine off the dyno.
From memory we were 8% richer than stoich for MS109.Lloyd klem wrote: ↑Sat Dec 03, 2022 5:15 pm You could pull a bunch of fuel out of that.Your pistons don't have near enough coverage imo.Need to get some texture too them.
Is the unleaded fuel making this look worse than what it is??
We can not run leaded fuel in Australia.
All exhaust ports and valves look like this
I thought on a 23 degree head you need that quench to help with mixture motion etc.In-Tech wrote: ↑Sat Dec 03, 2022 6:29 pm I assume this is an engine you built so I don't have to ask you about texture in the intake manifold or ports. The fuel is dropping out of suspension and you need less quench area. A lot of people thru the years have added fuel coolers . Cold air, hot fuel is a key. And yes, I agree with others, you are extremely rich. Some of this could be the fuel suspension problem.
Just for reference this has 0.030"
Piston to head clearance.
My chambers on the L-29 heads and piston crowns looked super after using a burr finish in the intake ports and chambers. I am sold on doing the burr finish after testing it with 2 different sets of heads. Never had intake ports so clean after a few races.
