A game changer in the flat tappet world ?
CamKing
Re: A game changer in the flat tappet world ?
Post by CamKing »
1972ho wrote: Sun Jan 22, 2023 12:37 am Believe it or not but I ran a set of tool steel dlc lifters on a iron solid flat tappet camshaft and it never damaged the cam are the lifter.And it had 200# of seat pressure on it 450 open.And I broke it in with a set of ceramic foot lifers first,and I was shifting at 72-7500 rpm 78-8000 at the stripe.
For how many miles ?
They won't last more than a season in circle track racing.
Warp Speed
Post by Warp Speed »
We developed the tool steel cam and DLC coated lifter deal in 2000. It was a true game changer in the cup world compared to the stelite overlay/chilled iron lifter we used for years. Virtually eliminated cam and lifter problems. The cam cores alone are 3k.
CamKing
Post by CamKing »
Warp Speed wrote: Mon Jan 23, 2023 5:39 am We developed the tool steel cam and DLC coated lifter deal in 2000. It was a true game changer in the cup world compared to the stelite overlay/chilled iron lifter we used for years. Virtually eliminated cam and lifter problems. The cam cores alone are 3k.
Yes, and like many other NASCAR innovations, it trickled down to the lower classes of circle track racing.
We had good luck, running the DLC coated lifters against different types of steel cams. The most economical. was induction hardened 1050 steel(about $750 + $1,500 for the lifters). It didn't take long for local tracks to change their rules, and make it illegal to run Steel cams in the flat tappet classes. That's when we tried using the DLC coated lifters on cast cams, but could never get them to last a whole season. I wanted to try putting in a cam tunnel, and flooding it with oil, but not to many weekend racers are going to want to do that.
BOOT
Post by BOOT »
I was bout to toss out this flyer in a recent order and noticed the Comp DLC Lifters, Also the Driven carb Defender, might have to try some of that.
BOOT
Post by BOOT »
Just got this in a email from Northern Auto Parts Link to ad https://www.northernautoparts.com/part/ ... 75c8c7686b
BOOT
Post by BOOT »
So would you break in a flat tappet cam like normal And then switch to these lifters Or use a cam specificity for them???
edit: Also I assume this would make flat tappet cams with these lifters more reusable engine to engine.
Monza355
Post by Monza355 »
BOOT wrote: Fri Jan 27, 2023 12:04 pm So would you break in a flat tappet cam like normal And then switch to these lifters Or use a cam specificity for them???
I would assume you would break them in like normal. They just seem to be advertised to take the guesswork out of the break in people have had bad luck with recently
Tom68
Post by Tom68 »
Hopefully CamKing can comment, my guess would be if the lifters eventually take out standard Iron cams as CamKing has noted they must never bed in in the first place. So yes then, put them on any cam whilst they show no signs of wear.
Might treat them like a new vaccine, give it 5 years to see what happens. At the price there should be a high takeup, disaster may start inside a year.
Not bedding in and flaking coating would be my fears.
CamKing
Post by CamKing »
Since no one has any real data on these, I'm going to lock this thread, until someone actually runs them.
It's not a "Game changer" until they're proven to work.
Right now, they're just a sales pitch.
Locked
