WB O2 guage install
dfarr67
WB O2 guage install
Post by dfarr67 »
Finishing up a turbo deal- DD, WB controller crapped out and need to replace. Option is to wire harness direct to ecu (it now has a built in controller) or add a gauge inside. Have any found it useful to run the gauge vs initial logging and tune?
Racer71
Re: WB O2 guage install
Post by Racer71 »
Gauge is nice to have, if an injector or something goes awry and it goes crazy lean you’ll have some indication on the gauge instead of going till things get bad. I usually wire up the wideband with a gauge and tied into hp tuners if I’m running one based on that software. With the standalone stuff there are various to do it using the integrated WB
