1/2" compression to 1/2npt 90 degree fitting help
54chevkiwi
Post by 54chevkiwi »
I'm looking for a 90 degree full flow fitting like the one pictured, I'm hoping to find one with a 1/2" npt on one end and a 1/2 compression fitting on the other.. anyone have a part number or link they can post please?
I'm trying to find one but aren't having any luck and don't know the words to look up..
54chevkiwi
Re: 1/2" compression to 1/2npt 90 degree fitting help
Like this but 1/2" compression fitting on the hose end
In-Tech
Post by In-Tech »
What do you mean by "compression" fitting? Barbed? picture?
-Carl
54chevkiwi
In-Tech wrote: Thu Jan 26, 2023 7:09 pm What do you mean by "compression" fitting? Barbed? picture?
Like these.. where I'm from I'd call them compression fittings because of how they compress the olive around the hard line.. I suppose that's not the right name, hence why I can't find them?
That for 1/2" hard line on one end and 1/2npt on the other of a 90 degree fitting is what I'm after..
In-Tech
Post by In-Tech »
I have not seen what you are after in a single piece.
Here are a couple links to what you can use for 2 pieces and the 90 still is full swivel.
https://jettstore.com/product/an-male-t ... l-adapter/
https://jettstore.com/product/an-female ... -tube-end/
Sniff around on that site, you can do it male or female.
-Carl
In-Tech
Post by In-Tech »
Money,
This looks like what you are after. The picture doesn't look right, but it is supposed to be for hard line on one end.
https://shop.hoseandfittings.com/catalo ... 46f88dbdb2
-Carl
54chevkiwi
In-Tech wrote: Thu Jan 26, 2023 8:19 pm Money,
Champion!
I appreciate the help. Sincerely. I really had been looking for a couple hours.
Thanks
