SBC oil pump wobbles
- New Member
Working on a 327. With the rear main cap torqued, the oil pump will wobble a tiny but when not bolted down. If I hold it down with my hand trying to apply equal pressure it still wobbles a bit. Both pump and cap are clean and I've tried several pumps. If I put the bolt in and start to tighten, no more wobble, but I'm thinking the main cap surface could be warped and cause an internal oil leak?
Re: SBC oil pump wobbles
A mirror or other flat surface and sand paper will flatten small stuff like that https://youtu.be/lp2AyejH2VU
Also they make copper gaskets https://www.summitracing.com/parts/sum-111480
- New Member
I thought about that, but I'm pretty sure it's on the main cap side so I'd have to be able to pull the stud the studs out. I think I'm overthinking and am just gonna send it.BOOT wrote: ↑Sun Feb 05, 2023 7:35 pm A mirror or other flat surface and sand paper will flatten small stuff like that https://youtu.be/lp2AyejH2VU
Nicely caught, I use a smear of old school Hylomar brush on sealing compound on that connection. Pain to pull the cap and dowel to get it flat, but if you don't you'll always be thinking about it.Callmewaylon wrote: ↑Sun Feb 05, 2023 5:29 pm Working on a 327. With the rear main cap torqued, the oil pump will wobble a tiny but when not bolted down. If I hold it down with my hand trying to apply equal pressure it still wobbles a bit. Both pump and cap are clean and I've tried several pumps. If I put the bolt in and start to tighten, no more wobble, but I'm thinking the main cap surface could be warped and cause an internal oil leak?
There is probably something slightly amiss with the pump shaft or intermediate shaft.
By wobble he means it rocks by hand on the main cap before pulling down.Walter R. Malik wrote: ↑Mon Feb 06, 2023 3:25 pm There is probably something slightly amiss with the pump shaft or intermediate shaft.
Tom68 wrote: ↑Mon Feb 06, 2023 11:37 pmBy wobble he means it rocks by hand on the main cap before pulling down.Walter R. Malik wrote: ↑Mon Feb 06, 2023 3:25 pm There is probably something slightly amiss with the pump shaft or intermediate shaft.
OH ... I misunderstood.
I know you have probably already finished it up but I have had a couple that did the same thing and it turned out to be a slightly raised spot around each of the pins. You can barely hit the holes in the pump with a countersinking tool and then it sits flat.
This is a must fix in my opinion, oil pumps break occasionally from vibration so having it pulled down has to be putting an undue stress on the housing.Callmewaylon wrote: ↑Sun Feb 05, 2023 5:29 pm Working on a 327. With the rear main cap torqued, the oil pump will wobble a tiny but when not bolted down. If I hold it down with my hand trying to apply equal pressure it still wobbles a bit. Both pump and cap are clean and I've tried several pumps. If I put the bolt in and start to tighten, no more wobble but I'm thinking the main cap surface could be warped and cause an internal oil leak?
I've seen metal swell up around the dowels, you can check it with a machinist square or any rule that is flat .If the tool rocks or you can see daylight then relieve the pump hole with a round burr until it doesn't rock.
