I'm wondering what would be the most effective approach--to run a five or six stage oil pump with no vacuum pump or to run a four stage pump with a vacuum pump?
Does anyone know if current Pro Stockers have vacuum pumps or do the oil pumps pull enough crankcase vacuum alone?
Thanks!
Dry sumps and crankcase vacuum
We have always used a vertical mill for lifter-truing with our BHJ kit, and as BHJ reccomends we would flood the reamer with the mill's on-board coolant pump. Now we have a seat and guide machine to speed up the operation, but cannot flood the area because of the mess it would make. What are some options that people are doing in the real world? Can I use cutting lube in a squeeze bottle while it cut? Or...???
Thanks,
Gerry
Thanks,
Gerry
