have there been any advances in guide material for the guys running big spring pressure (>1000lbs over the nose)? I have thought about running a stelite guide with a little additional clearance, but worry about it's ability to get the heat out of the valve...plus if it starts to wear, watch out!
Thanks
Dennis
guide material with big spring pressure
- Show Guest
Re: guide material with big spring pressure
In the Pro Stock engines I use the Beryllium guides. They DO NOT wear out like the bronze guides. They are much stronger and can take a lot more heat. I have had them in heads for five years before replacing them. I can also bullet them in the exhaust ports without having them flake, crack and melt away.airflowdevelop wrote:have there been any advances in guide material for the guys running big spring pressure (>1000lbs over the nose)? I have thought about running a stelite guide with a little additional clearance, but worry about it's ability to get the heat out of the valve...plus if it starts to wear, watch out!
Thanks
Dennis
Darin Morgan
-Induction Research and Development
-EFI Calibration and Tuning
Reher Morrison Racing Engines
1120 Enterprise Place
Arlington Texas 76001
Phone 817-467-7171
Cell 682-559-0321
http://www.rehermorrison.com
Phone 817-467-7171
Cell 682-559-0321
