SecretMy ex ports are also biased to the SSR and are oval in shape. I make them almost striate on the chamber wall side. If you think in terms of how much the gasses have to turn and bias the throat ( intake and exhaust) to the air flow, it will move more air every time. My intake throats are biased .050 to the SSR! That is trade secret not many people want us to talk about isn't it Bill.
yeah, i didn't want to mention it
i start off boring the seat insert area .90 % PerCent of Exh valve OD
but hand blend the radius seat , biasing the width along the lengthwise of the Head making it "Oval-Shape" or sort of "D-Shape" with the Short Turn Radius approx. .020" to .030" smaller across Long-Turn -to- Short Turn distance than the insert's width is to the lengthwise.
..so the insert is approx .91-.92 % in width (lengthwise to Head)
and about .905 - .91 sometimes Long Turn -to- Short Turn across insert
..this has to be done very careful , or port noise & turbulence can appear
in other words, removing more metal from sides (lengthwise) to long turn
, keeping the short turn radius fatter than the other 3/4 of the insert,
something like a D-Shaped Oval
maybe more like Bill was describing ????
you can create a very smooth Flowing/Sounding Exhaust port
using .88 -to- .89 % PerCent of Exhaust valve OD
and handworking/blending a sort of small venturi effect just under the .89 % percent bore area (not in the Long Turn Area), but if you need a little more Flow ,
you can go towards the .90-.91-.92 percent and Oval-D-Shape insert area
