Hot Honing
modok
Re: Hot Honing
Post by modok »
If hot honing works worse, the logical thing to try is going even colder. I haven't messed with it, not sure how the oil world work....
But I have tried quite a bit of cold machining, works great on aluminum.
Keeps building up on the tool edge?... Can't get a even surface finish?.... Freeze it! I'm not joking,
induction apprentice
Re: Hot Honing
Post by induction apprentice »
modok wrote: Wed Feb 03, 2021 1:02 am If hot honing works worse, the logical thing to try is going even colder. I haven't messed with it, not sure how the oil world work....
That is a very interesting point of view. Solid logic.
David Redszus
Re: Hot Honing
Post by David Redszus »
How cold do you go?
Chilled coolant? Compressed air? Liquid nitrogen?
modok
Re: Hot Honing
Post by modok »
Oh.. probably 20F,
due to my home shop being in a small outbuilding it just naturally occurs if I don't heat it.
David Redszus
Re: Hot Honing
modok wrote: Thu Feb 04, 2021 12:24 am Oh.. probably 20F,
Chilled coolant could be easily done; it would help keep the workpiece at a near constant temperature.
But honing temperature does not matter as much as the temperature at which the work piece is measured.
AUTOMAN
Re: Hot Honing
Post by AUTOMAN »
200° maybe a bit hot so I do it at 350°F
Pain in the ass, but works for me.
Oven heat with plate, hone, cool, measure.
Chasing OOR and taper without over shooting size is the biggest PITA.
cliff
stealth
Re: Hot Honing
Post by stealth »
My assumption is that developments in modern thin rings and coatings and coatings has made this much less of a factor... bore finish and excellent ring land in piston along with modern ring package is where it's at.
Re: Hot Honing
AUTOMAN wrote: Sun Feb 14, 2021 2:41 am 200° maybe a bit hot so I do it at 350°F...
Did you mean 150°? :?
nhrastocker
Re: Hot Honing
Post by nhrastocker »
Hot honing has its place and I believe there is a bit of a skill that is developed from actual experience.
One of the guys that has perfected the hot honing technique is Pro Stock engine builder Nick Ferri.
The last time I was at his shop, he had a large number of not only Pro Stock engine blocks from other racing teams for hot honing, but also Harley Davidson Pro Stock cylinder cases and other Comp Eliminator engine blocks. My personal experience with his hot honing is that the engine sealed faster and all the exhaust ports were drier and cleaner.
AUTOMAN
Re: Hot Honing
Post by AUTOMAN »
Nope-350F
B+S race engines can run that hot on the bore.
Ring seal and overall engine friction are the 2 low hanging fruit.
cliff
