AdioSS wrote:Wolfplace wrote:I guess my question is after measuring more than a few blocks with a head bolted on or a plate bolted on is why the hell would any place calling itself a performance machine shop not use torque plates?
How many different kinds of engine blocks does the average shop work on?
How much does a torque plate cost? Do you have iron plates for iron head engines and aluminum plates for alum head engines?
If you specialize in a few of the more common engines, then it makes sense to have plates for each.
I have been told that if you simply torque down some washers instead of using a complete plate that you will get most of the benefits of the plates.
I guess it depends on how long you have been doing this as to how many different engines you have seen
I have seen my share in the last 40+ years
And let's just say I have a lot of money tied up in plates.
I do not care what the plate costs, if I am going to do a block that should have one I am going to have a plate.
I do not use aluminum plates, I have not found any measurable difference in bore distortion in the few I have compared.
Bolts & washers:
Been there, done that a long time ago & it ain't so, even the gasket used makes a measurable difference in some cases
I think this was probably started by people to cheap to buy or to lazy to use plates,
