HEAD/ DECK FINISH
HEAD/ DECK FINISH
What head and deck surface finish works best with copper head gaskets
It's an iron block and iron heads?
Am i right in thinking that as smooth as possible is best?
What about coating the gaskets before installation?
Cheers and thanks
Cheers and thanks
- Wolfplace
Hi Ari,
I like very smooth surfaces & use Hylomar spray. Good stuff
Also, I always use a reciever groove with an "O" ring.
That said, with the Cometic MLS gaskets I don't find much call for copper anymore except for the 'die hards"
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
finish
Thanks Guys
Hi wolfie. Got that dyno happening yet?
Thought about running cometics but the block had been o ringed and run copper in the past. Now been tapped for 1/2 inch head studs and we'll give it another go.
Cheers
Ari
Cheers
Ari
O-RINGS
HI Fatman
My block was set up with orings as well. Dont laugh at this and dont anyone else laugh either
I left the stainless steel o-ring in place, went and bought a very fine flat file and spent an hour draw filing over the orings.
I was able to get the orings level with the block and under my coke bottle glasses the finish looks great and I intend to use cometics
Trev
Trev
Hi trev.
Cant see why it wouldn't work as long as that remaining o ring was pretty stable in there
What about pulling the o ring out an filling the groove with something like JB weld. Wonder if that would work.
If you're interested, the motor was a flat tappet 355. VNs, Harrop, holley 950 HP etc. Went 10.30 @ 129/130 in an early Commodore, VC i think. That was with both heads gaskets blown into the valley on the centre 4 cylinders. Hopefully go low tens if the gaskets can hold up. Might give you some idea of the potential of your combination with the superior heads, cam and extra 28 cu inches.
Cheers
Ari
Cheers
Ari
- Wolfplace
Re: finish
Hi Ari,,Fatman wrote:Thanks Guys
Cheers
Ari
LOL,, no, got the old one out & crated & the new one is bolted to the floor with wires going everywhere,,,,
Got a half dozen engines I am supposed to get done & dynoed & the days just seem to disappear
Damn near another week shot in the ass & still don't seem to have anything accomplished
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
- Wolfplace
Re: finish
Yes, both sides & a thin coat on copper. Nothing on MLSFatman wrote:Wolfie,
Are you saying to spray both sides of the copper gasket with the Hylomar? If so, just a thin coat or what?
What about Ra measurements (hope the terminology is right) for the deck and heads?
Cheers
Ari
I don't think you can get it too smooth with MLS gaskets.
I like 30 or better, especially on the aluminum.
I think copper is a lot more forgiving regarding surface finish but I still don't like surfaces that look like they were done with a dull cutter or a body grinder,,
A lot of the new blocks are too rough the way they come, well over 100
Everything I do is normally around 40 or better but with cast iron you need to check in a number of places to get a true reading as the surface "voids" or "imperfections" will fool the profilometer & you will get a higher number than you really have.
If the surface "looks" good everywhere & you are getting hi readings, check a number of places.
The lower readings are what I feel are more representative of the true finish.
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
- Wolfplace
Doesn't seem to make much difference with copper.
I have taken apart engines I wouldn't think would seal they were so bad & they apparently were fine.
You could "see" the finish in the gasket big time.
I just prefer surfaces on the smoother side,, for a number probably 70ra or so is fine with anything except MLS.
I see a lot of surfaces that are not acceptable to me like some of the new blocks but again, they seem just fine in practice.
A 70 RA finish is still pretty smooth & at one time was considered a very good one.
I think you would have to be pretty bad to cause a problem with most gaskets with cast iron.
Aluminum is another story
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
