dart little chief vs. sb 2.2
The Little Chief heads require the block to have the lifter bores in totally different locations than a factory style block and the angles are also different (43* intake/ 46* exhaust). ChrisU, yes, you turned your block into a "regular" Iron Eagle block, with a higher raised cam bore. Dart offers putting the lifter bores into a Little Chief block for an additional charge, but will only do it at the angles for a Little Chief head, and the bores are bushed for the Jesel keyed lifters. The cam bore in a Little Chief block is raised .434" vs. .391" on a Iron Eagle block. A custom cam core is required as well (since the lobes are in different locations). Intakes are unique to the Little Chief as well and do not interchange with the SB2 stuff. Definitely BADASS but you must be comitted to go all the way.
The Splayed valves are used in Pro Stock, but I would imagine it would be the V8 Super Cars (Circuit class roundy round stuff) that would be pushing the use of the Splayed stuff. With a few rule changes a couple of years back for parity of the class, the GM racers, some of which are factory backed, had to go with the GM splayed Valve heads, and the Aurora based block. This was so the valve layout was like the Yates heads, and the Aurora block was the same deck height. Some revisions were made to the Auroa castings (engine mounts etc), and I believe that revision is called a Holden Motorsports block.
With the Main class, and the development class, I am sure they would be using anywhere from 30-50 pairs of these heads a year. There would be lucky to be 15 pairs in Pro Stock in Australia, and the majority of these engines are sourced out of the US anyway.
Sorry to hijack, back to the action
AL....
AL....
I was Looking around at some Little Chief heads on the net and came across a set from They had a flow sheet of a 345cc head and it flowed right at 470cfm at 1.0" lift. But at the bottom of the page and in very small print it said, flowed a .50" of water. wont your flow #'s be alot higher at that setting, rather than 28"? I know from reading here flow is not everything. But alot of people buy heads based on that number. Would that 470cfm number be alot lower if it was flowed at 28".
GMs splayed valve head will smoke both the sb2.2 and the little chief. I can't speak from exeriance, but a friend of mine works with them often and taught me alot about them. Its unbelievable the capability of HP they can produce. Hopefully He'll chime in in the next few days to share his experiance.
Ricky, you out there??
Mike Theroux
www.mikesportingservice.com
Mike Theroux
Mike Theroux
www.mikesportingservice.net
There is never enough time!!
Don't know if I would totaly agree with that, .. L chief is a strong part.highVE wrote:GMs splayed valve head will smoke both the sb2.2 and the little chief.
Mike Theroux
The older casting splayed valve used to be a real
, .. um, . .problem to work with.
Curtis
Race Flow Development
The little chief is based off of the pro stock truck heads that Carl Foltz did which was a sectioned and re-welded GM casting.... with that being said I think that the little chief is a better head than the GM casting, which is one bad dude in its own right when modified correctly! The most power per inch stuff that I have done was with that casting. Happy holidays to all!!!
new sb2.2 Rox
Does anyone now about the new "rox" sb2.2 http://www.who-sells-it.com/ctp/245/153/full/ head and how it compares to the little chief or how much better this compares to the last sb2.2 head
possibly 2.250 or 2.300 intake on these?
Anthony
Anthony
- New Member
Mike, thanks for calling me out on this
I have limited experience with the little chief head, and a lot of experiece with the splayed valve gm head; therfore I favor the gm head. I will be working on a set of little chiefs after the holidays, so maybe they'll impress me, but so far they haven't.
I began working with jeff and lump as the pro stock truck class was ending and making its' transition into comp so I don't know the whole story behind cfe's little chief splayed valve hybrid. I can see the advantages of the intake runner layout allowing the manifold plenum to be shorter front to back and getting the runners under the carbs better, but I don't really like the left and right ports. Plus the set of little chiefs I have at the shop aren't that thick in the places I would of thought the casting designers would have placed more material. I agree with everyone that the splayed valve has its' share of design flaws, but nothing that can't be fixed with a good welder. I too am awaiting gm's release of a redesigned splayed valve head and 15* casting to alleviate some of the work that has to be done to them.
Darin stated that a little chief motor a little under 400" could make 1080 hp. That would be stout considering our best 400" splayed valve motor only made 1045.(Roger Brogden's A/SM motor)
If we could get the splayed valve head like a DRCE casting I don't think there would be any argument whether it was better than the little chief.
The sb2.2 rox head is for the new 4.500 bore space blocks, so yes it will have better capabilities than the standard sb2.2 head.
We just finished our first 4.500 splayed valve headed motor that will be replacing the customer's old 4.400 splayed motor. Should know in two weeks how much faster it will be capable of going.
I think of it this way: little chief= little sister of 11* big chief
gm splayed valve= little sister of DRCE pro stock head
I don't think KB Racing is running big chiefs
Hope I didn't step on any toes as that was not the intent of this post; just an explanation of one man's opinion. Merry Christmas everyone and sorry for the long post
Ricky Mcconathy
Ricky Mcconathy
Naiser Racing Engines
713-688-8383
713-688-8383
