Could someone help identify these SBC castings?
ChadS
Post by ChadS »
Mike Rogers
Post by Mike Rogers »
Trick flow twisted wedge heads.
Mike Rogers
215-674-5240
EQ Cylinder Heads
http://www.rogersperformance.com
ChadS
Post by ChadS »
Thats what I was thinking ( I am a SBF guy) it just looks like they are real old and there is absolutely no Trickflow markings on them.
Thanks.
Mike Rogers
I don,t htink they make them any more.
Mike Rogers
215-674-5240
EQ Cylinder Heads
Wilkes
Post by Wilkes »
They are likely of mid 90's vintage. You can call or email trickflo with the serial number stamped in the head and they can give you the details. The early ones had iron valve guides and it's a good idea to replace them with bronze. Those look like the swirl vane in the intake has been cut out. Getting the rocker geometry on the intakes right is tedious. Comp makes a special rocker with an offset shaft to help. I have the part # somewhere, if you need it I'll hunt it up.
John
ChadS
Post by ChadS »
If you could that would be great and thanks for the help guys it is greatly appreciated.
Wilkes
Post by Wilkes »
The comp rocker is #1307. It's a pro-magnum rocker with the rocker stud hole in the shaft off center to help with the rocker geometry. You use them on the intake side only.
John
machine shop tom
Post by machine shop tom »
I have re-done several sets of those heads. Each of them had WASTED valve guides and every spring dampener was broken.
tom
Pray for a secular future.
We used to speak to tell things , now they tell things to speak.
Si Vis Pacem, Para Bellum
user-z68766209
Post by user-z68766209 »
I believe those take a real short valve. Only from
TFS also after re guiding make sure to check
center line of guide to spring pad being square..
Brian B
Dakota Parts Warehouse
The Ferrea Valve Guy
877 235 2832
rebelyell
Re: Could someone help identify these SBC castings?
Post by rebelyell »
MikeMighty wrote: Sun Dec 05, 2021 11:39 am I cannot get it.
welcome to the forum ... let's just hope they've fixed it by now ... it's been nearly 15 years.
Chris_Hamilton
Post by Chris_Hamilton »
Spammer [-X [-X [-X
